sta loks untwisting with blue loc tite? - SailNet Community
post #1 of 9 Old 10-03-2014 Thread Starter
Hi. I had written a nice long ranting post, but it got lost somewhere on the internet. I'll spare you guys the details this time.
I rebuilt my rig with sta loks. I followed the websites instructions. I also used life caulk and blue loc tite on the fittings.
Went sailing a couple times. I was fidding with my backstay adjuster which is one of the mechanical turnbuckle like ones. and plop the upper part of the backstay falls on deck. It had untwisted after two sails and a couple of days of life caulk and blue loc tite curing.
I had my yard/riggers go up and reinstall it and make sure the other fittings were tight. a couple needed a turn or so. They recommended red loc tite.
I am probalby going to take apart the side stays myself. Have them do fore and back as I don't like climbing mast with a halyard holding it up. Eventually replace fore and back stay with swaged on fitting. I just can't trust it as it is.
Anyone else have such an experience? Any have a rig stay up forever with red ? untwist with red? blue? none? screw it and swage them all sta lok for emergencies.
Things I learned re rigging
1. Measure a lot . cut once. too long in this instance is ok ish. too short very bad.
2. Consider swaging on those stays that have a twisting force applied. Fore stay and back stay. use red loc tite.
3. Don't overtighten the rig. Easier than you think to do when really trying to get that straight mast at the dock . (I didn't do this but was getting closer to it rather than farther away)
seafarer30 is offline
post #2 of 9 Old 10-03-2014
overbored's Avatar
Re: sta loks untwisting with blue loc tite?
Never had a problem but I do not use loctite or anything on the fittings. The instructions do not mention using anything. where did you put life caulk on a sta lok, that would be like putting a lubricant on the fitting. A big no no in my book. Only time I have seen one unscrew is on a forstay with a furler foil that was below the fitting. Harken now say to not do that.
http://www.stalok.com/t-stalokterminalinstructions.aspx
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 9 Old 10-03-2014
Chastened
Ajax_MD's Avatar
I re-did all of my rigging this past winter with Norseman and Hi-Mod fittings.
RED Locktite is the order of the day. Accept no substitute.
I've sailed in plenty of snotty chop this year, out in the Atlantic and back. Sent folks aloft with cameras and everything is as solid as the day I made them.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #4 of 9 Old 10-04-2014
aeventyr60's Avatar
Never had a problem with the blue loctite on my staylock fittings. Think you need to use a longer wrench and really torgue down those fittings. Recheck the fittings with a wrench after you've put a few miles on.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #5 of 9 Old 10-04-2014
tommays's Avatar
A well calibrated elbow is no substitute for a torque wrench
blue holds against minor vibrations red done right needs heat to open
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 9 Old 10-04-2014 Thread Starter
In response to overbored I followed these instructions. http://sailmahalo.com/picture_collec...allingStaloks/
I cranked pretty good on the sta loks. Company instructions explicitly warn about overtightening. Next time I'd use a bigger wrench though.
The pros at my yard are really pushing life caulk and red loc tite. My short experience agrees with them. I had to redo a couple fittings so next time I tackle a rig I would get a decent dry fit and then red loc tite and life caulk on final assembly. Anyways hopefully the post gives a couple of tips.
post #7 of 9 Old 10-04-2014 Thread Starter
Huge yes on rechecking after a few sails. Also,going to have the yard go up with a lift and reassmeble fore ans back with the red stuff.
post #8 of 9 Old 10-04-2014
Do let the lifeseal & locktite cure a bit longer. Make sure your putting the on them the sealant in the bottom of the fitting and locktite on the threads that have no sealant. The sealant will squeeze out after the locktite makes contact. Always always undo and check your wire lay after initial assembly. Then clean threads with solvent before applying locktite.On larger fitting I use a never seize product for initial assembly then must clean threads before final assembly. this eliminates the galling that may occur.
All that said most likely what happened is you let the stay turn when adjusting your back stay therefore actually undoing the fitting your self . Make certain you do not let the stay turn when adjusting any turn buckles swagged or mechanical fittings.
May you weather all storms
dorymate1 is offline
post #9 of 9 Old 10-04-2014
Loctite is funny stuff. Most people are unaware that it has about a two-year shelf life, and at that point it will never cure properly and should be thrown out. And even new and fresh, it won't work properly unless the parts are BOTH very clean, which can mean clean rags and alcohol or other prep to get any machining lubricant, grease, etc. off them.
If you have the prep wrong or the goo is too old, even red Loctite can be spun off with no effort, by hand. If you do all the prep right, the red stuff will have a much better grip. The stuff DOES work, but only if you follow the directions. (Don't ask me how long it took before I did that.(G)
hellosailor is offline
New halyard: Sta-Set or Sta-Set X? TakeFive General Discussion (sailing related) 45 09-06-2014 06:34 PM
Untwisting jib sheets? rbyham General Discussion (sailing related) 7 08-22-2014 03:17 PM
Cast loc fittings IPR Gear & Maintenance 15 04-09-2012 09:03 PM
Sta-Lok or ? killarney_sailor Gear & Maintenance 22 11-06-2008 08:55 PM
Loc. of Frank Guernsey? kmeeks General Discussion (sailing related) 0 02-28-2003 01:01 PM
