Ace Hardware Antifreeze deal - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree2Likes
Old 10-04-2014
mbianka is on a distinguished road
For those who will be putting their boats on the hard over the winter. Ace Hardware here in the states has a good deal on -50 degree Antifreeze for water systems for the next few days. $1.99 per gallon. Limit of two. At least the stores in my area have the special.
Mike
BIANKA: sailing the Isle of Long waters these days
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 10-04-2014
HUGOSALT is on a distinguished road
Re: Ace Hardware Antifreeze deal
Thank you! Hope not to be using for a while but sadly eventually will...
  #3
Old 10-04-2014
pdqaltair's Avatar
pdqaltair is on a distinguished road
If it is Camco Artic Ban, that is an ethanol/PG blend and is a price-point product. Corrosion protection is unimpressive.
Probably false economy for most. Camco Freeze Ban is a better product (all PG, better corrosion protection) more suited to the marine market.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
  #4
Old 10-04-2014
capt jgwinks is on a distinguished road
For your plumbing it should be fine if your temps don't go below -30 or so. Use the good stuff in the engine.
mbianka likes this.
  #5
Old 10-04-2014
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
So if I put that -50 antifreeze in my engine, won't that make the engine too cold to run? What kind of oil do I need if the antifreeze makes my engine that cold?
  #6
Old 10-04-2014
Minnewaska will become famous soon enough Minnewaska will become famous soon enough
Nothing other than -100 is used to flush the raw water cooling system on our motors. That's the burst point, the actual freeze point is much, much warmer.
The freeze point for -50 deg antifreeze is around +15 degs (that's plus 15!) No thanks.
Jeanneau 54DS
  #7
Old 10-04-2014
Rhapsody-NS27's Avatar
Daniel - Norsea 27
Rhapsody-NS27 is on a distinguished road
That may be the freeze point but it still won't expand until a lower temp. Of course, if it's diluted, then the freeze point will be even higher. I just ran 10.5 bottles of -50 through my engine (2GM). Some left over from last year so just wanted to use it. I think my engine will be good this year now my boat is back on the trailer.
Some good points about dilution of anti-freeze: Engine - Winter Freeze Protection Photo Gallery by Compass Marine How To at pbase.com
Here's a video, thanks to Maine Sail
https://www.youtube.com/watch?v=h3d2DGIPEAQ
Daniel
1981 Nor'sea 27,
Aside from what it teaches you, there is simply the indescribable degree of peace that can be achieved on a sailing vessel at sea. I guess a combination of hard work and the seemingly infinite expanse of the sea - the profound solitude - that does it for me. - Billy Campbell
  #8
Old 10-04-2014
Originally Posted by Rhapsody-NS27 View Post
That may be the freeze point but it still won't expand until a lower temp. Of course, if it's diluted, then the freeze point will be even higher. ......
Dillution is another reason I do not use -50 in the motor. There are all sorts of nooks and crannies in the exchanger that may not displace, but rather mix with the antifreeze. -50 degrades exponentially.
As for freeze or burst, I don't like the odds in between. Expansion that hasn't yet reached the theoretical size/pressure to burst something?? Again, no thanks.
Antifreeze, should prevent freezing.
Jeanneau 54DS
  #9
Old 10-05-2014
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
Trying to wrap my head around the freeze point being so much less that the rated freeze point listed with a 52% glycol freeze point listed as -40 deg f here's the chart I found FREEZING POINTS FOR SOLUTIONS OF ETHYLENE GLYCOL
GLYCOL
% BY VOLUME
°F
°C
12.5 25 -4
17 20 -7
25 10 -12
32.5 0 -18
38.5 -10 -23
44 -20 -29
49 -30 -34
52.5 -40 -40. Freezing Points of Ethylene Glycol Mixtures
Illegitimus Non Tatum Carborundum.
  #10
Old 10-05-2014
Maine Sail's Avatar
GLYCOL
% BY VOLUME
°F
°C
12.5 25 -4
17 20 -7
25 10 -12
32.5 0 -18
38.5 -10 -23
44 -20 -29
49 -30 -34
#1 OP is talking about an "RV" antifreeze. A good-50 product will not be a 50% blend but rather much less, usually between 26% and 31% PG. West Marine Pure Oceans -50 and Star Brite Antigel -50 are two of the best -50F products you can buy (Practical Sailor Sept 2014) and they both have good corrosion inhibition packages too.
#2 We are not discussing EG but rather a PG product. Course the one on sale is not at all likely to be propylene glycol but rather a cheap alcohol blend..
#3 Regardless of what you use for a PG you need to ensure it has not been diluted. The best way to know this is by physically testing what comes out the exhaust or faucets with a refractometer.
______
-Maine Sail / CS-36T
You may post attachments
You may edit your posts
Sailing: Finn ace Ainslie anchors Olympic record NewsReader News Feeds 0 08-05-2012 10:20 PM
Ace sails, CT ben48 General Discussion (sailing related) 6 03-06-2012 11:28 AM
Sailing: Brazilian ace claims gold again NewsReader News Feeds 0 12-17-2011 04:40 PM
Cascade 29 - Good deal/Bad deal? jcwhite Boat Review and Purchase Forum 3 04-24-2011 01:49 AM
Automotive antifreeze vs. RV antifreeze for engine. dman535 Gear & Maintenance 18 09-30-2009 04:53 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
