-   -   Globe Impellers (http://www.sailnet.com/forums/gear-maintenance/16983-globe-impellers.html)
Warren M. 06-07-2006 06:32 PM
Globe Impellers
Anyone have any experience, pro or con, with Globe Impellers? They are advertised as being able to run without water in the pump or 15 min or more. Are they a worthwhile product?
berwick1 06-07-2006 10:55 PM
The only negative I have heard is that they do not push as much water as regular ones - maybe they are a bit softer?
Richard
Dawkahab 08-15-2006 01:05 AM
Globe impellers were originally sold under the name Barco. Many years ago there were some problems with them coming apart in short order. That has, to the best of my knowledge been solved. I have used them satisfactorilyfor several years in both main engines and generators and have accidentally run them dry for a minute or two. One thing I have noticed is that they fail less sudenly than neoprene. On my own boat I have water flow alarms on all engines. When I notice the alarm coming on at idle I know it is time to change the impeller. I have yet to chase pieces in the heat exchanger.They seem to outlast neoprene by at least 2/1 so as with most things even if they cost a bit more up front they are worth in in the long run. "Only the rich guys can afford the cheap stuff"
camaraderie 08-15-2006 11:21 AM
They are great and well worth the extra few bucks. They last, take abuse and don't need to be changed after not being used for a while. Sure beats picking pieces out of the heat exchanger!
