cal 25 help - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree5Likes
Old 10-13-2014
concorde01 is on a distinguished road
cal 25 help
ok so decided to start a tread dedicated to the new boat.
i just picked up a call 25 for free. no outboard. no trailer. no sails.
what is a good size outboard for this boat?
were can i find good strong sails that arnt an arm and a leg. i mean over 1000 just for one? i cant do it. i don't care if they are used as long as in good condition
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 10-13-2014
Re: cal 25 help
Google 'used sails', and 'sailboat rig dimensions'.
There are several used sail outlets, on-line and local consignment where utility sails might be found for cheap. To choose, you need comparable rig size.
CAL 25 sailboat specifications and details on sailboatdata.com
Your rig dimension are on the above page. J is distance mast to bow fitting, I is deck to top of forestay, P is height from boom to top of mainsail, E is length of main along the boom.
A 6-8hp outboard should be adequate, but smaller will get you out there too. For longer trips you may need more power due to the increased odds of headwinds or current.
  #3
Old 10-13-2014
Ok I found a good running older evinrude 10hp for $100
othomas3 likes this.
  #4
Old 10-13-2014
MarkSF is on a distinguished road
Re: cal 25 help
I used to sail a Cal 25 with a 5hp. It was adequate. 10hp might be overkill, but if it's a good engine and only $100, I'd take it.
  #5
Old 10-13-2014
overbored's Avatar
overbored is on a distinguished road
Re: cal 25 help
make sure it is a long shaft outboard with a prop for a sailboat
Cal 25 main for $ 495 http://www.minneysyachtsurplus.com/mainsails.html
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #6
Old 10-13-2014
Ok. Can I use the buccaneer sails as a temp?
  #7
Old 10-13-2014
krisscross's Avatar
krisscross is on a distinguished road
Re: cal 25 help
Be prepared to pay at least $800 for both sails if they are in decent shape. First thing, you have to get the sail dimensions right for your boat. Raise the measuring tape with the main halyard to make sure you have a standard rig, and measure your boom.
If you get sails that do not fit your boat, adjusting them to size will cost you another $300 or more.
Plato
  #8
Old 10-13-2014
krisscross's Avatar
Re: cal 25 help
Measure them to make sure that they are not too big for your rig. If they are a tad smaller, that is not a problem.
Plato
  #9
Old 10-13-2014
Ok ty
  #10
Old 10-13-2014
Ok because they are good sails. And d like to use them for awhile
You may post attachments
You may edit your posts
Cal 2-29 vs Cal 2-27 (Crown 28, actually...) saltfree Boat Review and Purchase Forum 9 10-20-2012 06:53 PM
Looking for someone with a Cal 2-46 pos3idon General Discussion (sailing related) 1 07-17-2009 02:17 PM
Cal 29? Scuppers52 Boat Review and Purchase Forum 3 04-22-2008 08:07 AM
CAL 2-25 aka CAL Mach II for Sale NewsReader Mass Bay Sailors 0 07-07-2007 04:15 PM
Looking at Cal 2-27 dagerman Boat Review and Purchase Forum 3 09-06-2003 12:50 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
