Advice on hurricane anchor. - Page 2 - SailNet Community
post #11 of 16 Old 06-21-2006
Surfesq's Avatar
SailingDog: I am sure you can relate to this. I tried anchoring at Block Island with a Fortress and that sucker dragged all night until I motivated and dropped a proper plow. I would not recommend one of those for anything but keel iron for all of the reasons stated herein.
Craig: Great information!
Surfesq is offline
post #12 of 16 Old 06-21-2006
Anchorsmith
Craig Smith's Avatar
Arrow
Craig- Just a question... how do you get a LOA of 5 tonnes? LOA-Length Over All.... not a measure of displacement.
... rated at that LOA (26'), for a displacement of up to 5 tonnes ...
Thanks Surfesq.
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Craig Smith is offline
post #13 of 16 Old 06-22-2006
Oops...
Must of missed the at when I read your post.
BTW, I'm very happy with my Rocna... got a 15 kg. model for a 28' tri.
sailingdog is offline
post #14 of 16 Old 07-03-2006
Any thoughts on storm anchoring a 35 ft. Catamaran on the Central East Coast of Florida? It's mostly mud bottom so I was thinking a Fortress FX-37 as primary and either using my 35 lb CQR and/or buying a 35 or 44 lb Delta as secondary(s). I have 3/4" 3 strand nylon with 40 ft. of 3/8" HT chain on one line for the primary and 25 ft. 3/8" proof coil for the secondary. Any thoughts on that setup? Should I consider using three anchors?
surfnrg is offline
post #15 of 16 Old 07-03-2006
Anchorsmith
Arrow
You shouldn't consider using three anchors any more than you should consider using two anchors; in other words less is better. One should always be enough except in the most extreme circumstances, and then two should be able to hold anything. The logic here being that you wouldn't want to be handling the size anchor that would be required if only one was to be used, because said extreme circumstances are not normal. If you "need" to add more, then you are using the wrong anchors, either in terms of type or size, or something is wrong with the rode set-up. You can't solve those problems by just adding anchors as the issues are fundamental and you need to back-up a bit.
Are you talking about rigging these anchors in tandem? Read the above posts again thoroughly.
  1. Tandem anchors should be of the same design or very similar. You are asking for trouble using widely varied types.
  2. Danforth-types (Fortresses) are to be avoided in any tandem rig on account of re-set and roll-stability issues, which get exacerbated once you introduce the complications of any dual rig. Having said that you would probably get away with it in soft mud. Still not ideal.
  3. No plow, including the Delta, works particularly well in soft mud. Too little fluke area.
Also get more chain. You're talking about 44lb anchors and only have 40' of chain, and none at all on your secondary? That's okay, if marginal, on a cat of your size for the most part, but not for storm anchoring.
Suggestions:
  1. Double the amount of chain. If you are talking about a tandem rig, you will also need about a boat-length of chain for between the two anchors (do NOT use rope). The latter does not have to be the same grade as the main rode, it can be lighter as it has to deal with only half the stress and there is no requirement for catenary.
  2. Dump the CQR, 33lbs is a bit small anyway and offers no fluke area for mud. Keep the Fortress despite its flaws; it's a good auxillary and is lightweight and easy to store. Then get two similar modern design anchors (not necessarily ours - consider Spade and others); perhaps 15Kg (33lbs) and 20Kg (44lbs), depending on the displacement of your cat which you don't state. The heavier pick you can use as your primary in normal conditions, and bring out the other for your storm anchor rig.
Craig Smith
post #16 of 16 Old 07-03-2006
Location: Aboard SoulMates somewhere in the Eastern Med
I can only tell you what worked for me year before last in Miami - i have 40 Jeanneau and my primary anchor is a 44lb cqr with 70' of 3/8" chain and 250' of nylon 3/4" rode - the second anchor is a 55lb delta with 70' of 1/2" chain and 250' of nylon 3/4" 3 strand rode. I anchored in about 10' of water, i draft 4'11", and used both anchors at about a 20 degree angle and put out about 100' of total length. she did not move through 2 named storms - she did do a 360 as when i pulled the delta it's rode was wrapped around the cqr rode. the bottom by the was is mud - the delta came up fairly easily whereas the cqr was buried and took a bit to get it up.
good luck and remember the winds will come at your boat from at least 3 different directions - so you have to prepare well and try to guess which will be the strongest for the longest period of time - last year i set up for wilma assuming a strong prolonged west wind but it moved farther north and we got an all night east wind followed by a short intense south wind followed by an intense west wind.
imho you can not get to much anchor or chain
good luck
chuck and soulmates
chuck5499 is offline
Intermediate sailor seeks advice re: liveaboard pocket cruisers Libby Cruising & Liveaboard Forum 22 03-26-2008 08:18 AM
hunter 40.5 anchor windlass DONLESLIE Gear & Maintenance 2 05-30-2006 10:33 PM
Anchor Wash down Systems MikeBr Gear & Maintenance 2 07-23-2001 08:53 PM
Anchor light syrenab General Discussion (sailing related) 1 04-15-2001 07:39 AM
Advice for breaking into racing dzipkin Racing 3 12-04-2000 03:02 PM
