Boat Us conducts anchor tests - SailNet Community
 33Likes
post #1 of 115 Old 10-20-2014 Thread Starter
Interesting results conducted by Boat US on popular anchors. See Oct. issue of 'Seaworthy' as the results where not surprising...
http://www.boatus.com/seaworthy/asse...nchor-test.pdf
aa3jy is offline
post #2 of 115 Old 10-20-2014
olddog60's Avatar
Re: Boat Us conducts anchor tests
Given a soft mud test the results are not surprising. That's why I have two anchors.
olddog60 is offline
post #3 of 115 Old 10-20-2014
MarkofSeaLife's Avatar
Dock
As I dont live in that country... Do ya wanna spill the beanz?
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #4 of 115 Old 10-20-2014
olddog60's Avatar
Not sure if links are ok. If not mods can take it down.
The Fine Art Of Anchoring Page 2 - Seaworthy Magazine - BoatUS
http://www.boatus.com/seaworthy/asse...nchor-test.pdf.
MarkofSeaLife likes this.
olddog60 is offline
post #5 of 115 Old 10-20-2014
Cruising at a snail pace
Based on the tests as an average I want to ony anchor on Day 4
But it was interesting how the old school anchor did pretty good against the new generation one.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #6 of 115 Old 10-20-2014
pdqaltair's Avatar
There was a long thread elsewhere. The area is known for layers of oyster shell and soft mud and is extremely variable.
My only take away is that when you are anchoring over a layered bottom with shells, there's no telling what you've got, even after you back down (you will feel a 500# set, but perhaps that is ALL you've got). I think it might be over-examining the data to say much about winners and losers.
Bigger is better and shock absorption helps, but moving is the only safe bet... if there is anything better nearby.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #7 of 115 Old 10-20-2014
Not Finished Yet
RainDog's Avatar
Got to like these results if you make the Mantus. I would expect Fortress/Danforth to own a staight line pull test in mud, but if I was only looking at this chart, i would buy a Mantus.
RainDog is offline
post #8 of 115 Old 10-20-2014
Why a soft mud test alone? It is very common there? Not a bottom very usual in Europe: Most anchoring bottoms are sand, hard sand, normal mud, and sand with vegetation. As someone said, the best anchors on soft mud have not a very good performance on other bottoms.
post #9 of 115 Old 10-20-2014
Not Finished Yet
RainDog's Avatar
Nothing but soft mud around here. Same in the Chesapeake as I understand it.
RainDog is offline
post #10 of 115 Old 10-20-2014
Am I reading this correctly? This is a test of an anchor's ability to set itself?
They lower the anchor, paid out 200 ft. of scope, (without having set it) then started reeling 100 ft in, at 10 ft./minute.
I don't read this as a test of a properly set and scoped anchor's holding power
It's a test of re-setting in a straight line..
or am I reading this wrong?
chef2sail likes this.
tempest is offline
anchor and boat design ? Why anchor the bow. Lou452 General Discussion (sailing related) 19 01-26-2014 08:05 PM
any tests or comparisons on batteries? rrgane Gear & Maintenance 12 04-03-2008 05:09 PM
Sailing: Barrington conducts Irish gig (Independent) NewsReader News Feeds 0 06-28-2006 08:15 PM
Anchor Tests windship Seamanship & Navigation 30 11-26-2002 01:08 PM
