Old 07-14-2001
halyardz is on a distinguished road
Folding Props...Advice/Experiences?
The boat that I''m buying has a Martec folding
prop. Any advice on operational characteristics of these rascals?
Old 08-07-2001
divad is on a distinguished road
I have a 2-blade Martek folding prop on my Sabre 28, and I have nothing bad to say about it. The boat handles fine in forward and reverse, prop walk is minimal. Just make sure you keep it clean; barnacles will hamper the folding mechanism as well as significantly reducing the prop''s efficiency and your speed under way. If it''s old, consider removing it and having it serviced by a prop shop. I had mine rebuilt a couple years ago: they replaced the hinge pin and refinished it and it looked brand-new when it came back.
Old 08-10-2001
sailacad is on a distinguished road
Mark your shaft with the blade vertical otherwise one blade will will hang down at slow speeds. Otherwise they work well but may provide a bit less thrust than a conventional prop.
Old 08-15-2001
paulk's Avatar
paulk is on a distinguished road
We like our Martec, though as mentioned, marine growth can hamper its opening properly and hurt thrust. If it does open unevenly, the throbbing vibrations let you know pretty quickly. Putting the engine in reverse and speeding it up seems to fix that problem, and then you can proceed normally. Newer versions of the prop apparently have interlocking teeth that even out the blades'' opening and avoid this problem.
Inboard fixed vs. folding prop & ratings mikehoyt Racing 6 06-06-2004 10:07 PM
folding prop chris1514 Racing 7 09-19-2003 10:43 PM
Remove folding prop dsiegfried Gear & Maintenance 0 03-16-2003 04:51 PM
Folding or feathering props on Lagoon 410 Mama_Cocha General Discussion (sailing related) 0 04-20-2002 09:00 AM
Feathering and folding props FredSprigman Gear & Maintenance 3 09-08-2001 06:21 PM
