06-16-2006
They're either sail slugs or sail slides depending on the design of the mast track. If it is an internal slot, then they're sail slugs and are either flat or round pieces about an inch or so long. If they go onto an external track on the mast, they're usually called sail slides or cars, and are a bit more expensive.
Defender.com is an excellent place to shop on the web. Give them a call if you have specific questions.
