06-16-2006
Question: Did you remove and clean the fuel filter? Also you could try a little Starter Fluid. If there is not much water in the fuel you can use Can Heat or Hyd Fulid to break up the water particals.
Just a couple of thought that might help before removing the injectors.
Take care
David
