Space constraint for starter battery? - SailNet Community
post #1 of 2 Old 06-17-2006 Thread Starter
Take Five
Question Space constraint for starter battery?
My house bank of four deep cycle batteries allows for space for my dedicated starter battery sufficient only for a standard "golf cart size" battery. Problem occurs that the single smaller dedicated battery isn't sufficient to turn the westerbeke 46 by itself. Knowing that we aren't supposed to mix gel cell and deep cyle if they are on separate circuits is it acceptable to use a single gel cell (much higher cca for the size) or should I not mix battery types at all regardless of the way they're wired?
Many thanks for sharing your wisdom and experience as usual!!
mikeedmo is offline
post #2 of 2 Old 06-17-2006
If the starting battery is on a separate charging circuit from the deep cycle batteries, it should be relatively safe to use different battery types. The real danger of mixing battery types is from the different discharge/recharge rates and voltage levels—which can cause accelerated battery aging and may be a possible fire or explosion hazard.
That said, I do use AGM batteries for my starting batteries, and deep cycle batteries for my house bank. I would like to point out that I do have the batteries on separate circuits, and the two banks have separate charge controllers, set to different voltages, set for what is optimal for the different battery types.
sailingdog is offline
House and Starter battery hookup gmenrule Gear & Maintenance 7 06-10-2006 07:21 PM
