generator auto-shutoff - SailNet Community
post #1 of 15 Old 11-03-2014 Thread Starter
Schooner Captain
UnionPacific's Avatar
I want my generator to be more safe.
Right now it may have an oil shutdown, but I am not sure.
I would like to add a water shutdown, but am out of ideas on this one.
At least out of ideas that would not cost close to $1000 to initiate.
Any thoughts how I might add a water flow shutdown?
I want to be able to sleep while it is running, or be on deck sailing, and not worry about it.
UnionPacific is offline
post #2 of 15 Old 11-03-2014
Re: generator auto-shutoff
Should be all manner of small line flow switches available.. have a look here:
Liquid Flow Switches/Meters
Simply wire it in with your fuel cutoff solenoid.. (assuming it's not a 'kill cable' type shutoff)
Faster is offline
post #3 of 15 Old 11-03-2014
Master Mariner
capta's Avatar
Every diesel generator I've ever had installed on a boat (or shoreside for that matter) has a high temp shut down that operates in conjunction with the temp gauge sender. Shouldn't cost more than a few bucks to install a normally closed sender (for whatever temp you desire) at the same point that your present temp sender is located and run it to the fuel solenoid power wiring. Engine gets hot, sender opens, cuts power to the fuel solenoid and Bob's your uncle; your gene goes to sleep. Easy, cheap and reliable.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #4 of 15 Old 11-03-2014 Thread Starter
Schooner Captain
EGT probe too? I want to save a burned hose and muffler.
post #5 of 15 Old 11-03-2014
In that case...Faster's post is the answer...flow sensor...
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
post #6 of 15 Old 11-03-2014
Master Mariner
capta's Avatar
So get a 200 degree sender. Generators are constant speed engines that rarely vary a few degrees in operating temp while operating, so if the standard operating temp is 180, 200 should do the trick before any damage occurs. What's an EGT probe?
Our Videos;
capta is online now
post #7 of 15 Old 11-03-2014
Brewgyver's Avatar
Exhaust gas temp.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #8 of 15 Old 11-03-2014 Thread Starter
Schooner Captain
I guess I need to time how long it takes the generator to hit a high temp under load with no raw water flow?
post #9 of 15 Old 11-07-2014
Missingyou's Avatar
Are you sure your generator doesn't already have a raw water flow switch. Many do, I found out the hard way. ;-) Long story short the o-ring on my strainer basket was missing after I took delivery. It ran for a bit but then the impeller finally gave up. It shut down quickly and would not remain running upon restart. They also may have an exhaust gas temperature sensor, as does mine. I assume this is to prevent a melted piston or valve?
See if you can find the original brochure describing the features of your unit.
Missingyou is offline
post #10 of 15 Old 11-09-2014 Thread Starter
Schooner Captain
no, I shut it off for a full min yesterday. It didn't notice. It was not under load, and the temp didn't go up at all. In other news the start/run solenoid is either bad or does not have a good ground.
Diesel Shutoff davidpm Gear & Maintenance 9 08-22-2013 10:52 PM
Diesel Full Cutoff (Shutoff) dvuyxx Gear & Maintenance 9 10-26-2012 02:04 AM
How does engine shutoff work? sailak Diesel 7 08-17-2010 09:25 PM
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 01:01 AM
Key vs. Fuel Shutoff dave6330 Gear & Maintenance 11 05-19-2008 09:02 PM
