Raritan PHII toilets - SailNet Community
 6Likes
post #1 of 18 Old 11-10-2014 Thread Starter
Pamlicotraveler's Avatar
I have two of these and thought until this year that I liked them. I have been chasing down leaks on both of them this year and have now realized that both of them have small cracks in underside of the base. All the rebuild kits in the world aren't going to solve that problem.
Has anyone else had this with the PHII heads? I am thinking replacing the base is going to be a pain, but that's where I'm headed I think. They are at least 10 years old, so I suppose it's inevitable.
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #2 of 18 Old 11-10-2014
Moderator
Jeff_H's Avatar
Re: Raritan PHII toilets
I have a Raritan PHII on my present boat and have had them on other boats as well. To me they represent one of the best of the reasonably priced toilets that are out there. I just rebuilt mine last spring and the parts were readily available through Raritan, although they are not inexpensive.
What I like about the PHII is that it needs comparatively little maintenance, the parts can be easily removed and replaced (unlike a similar priced PAR) and the parts are readily available.
If there is a shortcoming it is the connection between the base and the waste discharge elbow which can be difficult to seat properly with the force of any misalignment in a modern heavy wall hose. I actually made a small clamping device that I used to pull the parts together and in alignment so that I could get the bolts into place without straining the plastic. I also added large washers under the heads of the bolts and nuts to spread the load.
PalmettoSailor and bvander66 like this.
Jeff_H is offline
post #3 of 18 Old 11-10-2014
Schooner Captain
UnionPacific's Avatar
We have two. In stead of replacement, how about repair?
Grind a V shape into the plastic where it is cracked, and fill with resin, then put a single piece of fiberglass cloth on top and work it in. Will be surprised if that does not solve the issue.
UnionPacific is offline
post #4 of 18 Old 11-10-2014
BJV
Pretty sure material is poly based so not sure if epoxy will work.
I have two Raritain heads, one in steady use for 12 years now and still going strong.
my recommendation is check out raritain engineering site and order the replacement part and your back in business. Coat a few dollars but substantially cheaper than new head, and be a shame to swap out for a cheap weekend head.
Faster likes this.
bvander66 is offline
post #5 of 18 Old 11-10-2014
Going on 22 years with Raritan PHII in two different boats, few problems or complaints. They will provide parts, maybe more costly than you'd like but nice to stick with something that works..
Any chance it was ever frozen undrained?? Hard to imagine another way for that part to crack.
bvander66 likes this.
Faster is offline
post #6 of 18 Old 11-10-2014
You guys are making me feel very smart for replacing my Jabsco with a Raritan last year. Hope the PHC proves as reliable as the PHII.
So far, so good.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #7 of 18 Old 11-10-2014
Master Mariner
capta's Avatar
I hate the PHll heads, but we use ours every single day, not just now and then. Both ours cracked at the pump/exhaust hose junction and that requires a complete pump unit for replacement, nearly the price of a new head. I chose to replace the pump on one with the Jabsco electric conversion which solves the problem permanently and will do the other when I find a good deal on another Jabsco conversion or find a Wilcox/Crittenden Skipper head; now that was a great marine toilet!
I did try to repair one, but as mentioned nothing will stick to that plastic and even when I melted the same plastic as a repair it just recracked.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #8 of 18 Old 11-10-2014
BJV
Being using ours daily for 5 years (perm liveaboards) and only repair has been replacement of jocker valve. Cracked pump housing usually from frost damage or overtightening of screws holding jocker valve and outlet bracket.
raritain provides bare pump housing, no need to by complete pump.
post #9 of 18 Old 11-10-2014
Master Mariner
capta's Avatar
Not too much frost down here in the Caribbean. Last I checked the pump housing was around us$170.00, not all that cheap. No screw tightening will crack the housings at the base under the outlet fixture. The outlet design does not allow for the newer less flexible hoses of today, as mentioned above.
Our Videos;
capta is offline
post #10 of 18 Old 11-11-2014
aeventyr60's Avatar
A new Jabsco was cheaper then a new pump for the PHII. Same bolt pattern, so fit just right.
Now walking through Malaysian customs from Singapore toting a toilet over my shoulder was a different story....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Composting Toilets Pendle Gear & Maintenance 15 09-22-2010 08:47 PM
RARITAN PHII Standard Hand Toilet Stillraining Gear & Maintenance 5 10-09-2008 11:59 PM
Toilets wb8qcy Island Packet 1 02-18-2008 04:00 PM
Composting Toilets tumblebug General Discussion (sailing related) 1 02-10-2008 02:39 PM
Composting Toilets tjvanginkel Gear & Maintenance 23 09-23-2007 11:43 AM
