thru-hull electric connector - at least 13 pins - SailNet Community
post #1 of 3 Old 06-27-2006 Thread Starter
I'm trying to find a decent supplier of thru-hull connectors that will provide up to 13 pins in one male-female connector. I have found some that give as many as 9 pins but that's about it (see http://www.marine-electronics-unlimi...onnectors.html )
My goal is to be able to have one connector that ties in 3 Raymarine instruments wind-depth-speed so that I can remove the instrument "panel" when I want to. These 3 instruments have 5, 5 & 3 wires each.
I did find a supplier from the UK that manufactures a product called Dri-Plug http://www.driplug.com/ - they make one connector that provides 19 pins but with the British pound at $1.82 USD we're talking about 130 bucks - ouch.
Any suggestions are welcome.
skysurfer is offline
post #2 of 3 Old 06-28-2006
Why not do two nine-pin connectors, that would leave you some room for expansion.
You might be far better off putting the actual instruments inside the boat and using repeater displays on the exterior of the boat. Then you would only need to run a single three-wire SeaTalk cable through the deck. Much simpler...and easier. Wiring the panel will also be much easier.
Also, if someone nicks your external panel, you'll still have the original instruments inside the boat to use.
sailingdog is offline
post #3 of 3 Old 06-28-2006
sailandoar's Avatar
13 pin ???
These are very good connectors, Used by Raymarine on thier tiller pilots and are avail through most any large electrical supply house, mouser, newark, etc etc
=> http://www.bulgin.co.uk/Products/Buc...rStandard.html
sailandoar is offline
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
How to remove Vinyl lettering from Hull Sloop23 Gear & Maintenance 8 12-08-2006 01:02 AM
Hull number help, please thenrie General Discussion (sailing related) 4 06-25-2006 07:45 AM
Hull moisture MIKEHARTMN Boat Review and Purchase Forum 4 05-25-2001 05:35 PM
Hull Number?? WillS General Discussion (sailing related) 1 01-05-2001 08:06 AM
