  #11 (permalink)
Old 09-13-2009
Sea Slacker
brak is on a distinguished road
Incidentally, NMEA 0183 "speed restriction" is a fairly strange beast. They did for whatever reason define the speed to be fixed at 4800 baud and that certainly does set a very low limit.
However, protocol per-se (i.e. the set of sentences) does not have any specific speed limit and, as it stands, can be used to transfer 100s of thousands of sentences per second (as I currently do in PolarCOM "brute force" testing, primarily over the network). In fact, AIS which is "NMEA compatible" (i.e. uses the same format for it's sentences) tends to run at higher baud rate.
Of course the point of NMEA0183 speed is becoming somewhat moot since (unfortunately, in my view) many manufacturers are switching to either proprietary protocols or to the NMEA2000 (which is proprietary too unless you have a few thousand $$ to spend on the spec, and requires fairly complicated hardware interface, that you can't buy for $20 the way serial RS232 adapters are sold).
Nevertheless, most instrument and GPS vendors will provide either a compatibility output or a separate device that will speak NMEA 0183.
If you do plan on using a computer, use one with real serial port (rare nowadays, nonexistant in notebooks) or spend money on a better serial-2-usb adapter. Most cheap adapters are based on PL2505 chipset from Prolific. While the chipset itself is just fine, for whatever reason (cost savings, production issues?) these adapters tend to be flaky - some will work fine, some will only work on input or only on output and others not at all. More expensive FTDI-based serial-usb adapters tend to be more uniformly successful.
As a shameless self-promotion plug, check out PolarCOM Polar Navy for your NMEA processing needs
  #12 (permalink)
Old 09-14-2009
FrankW's Avatar
FrankW is on a distinguished road
Originally Posted by sailandoar View Post
SeaTalk=>NEMA: There are some folks out there that have done hobby hacks on seatalk to nema convertion.
.... and there is another one who does SeaTalk=>NEMA and NMEA=>SeaTalk convertion. Can be found on gadgetPool.de
Frank
  #13 (permalink)
Old 01-29-2010
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
Brak, I've downloaded the software and NOAA charts. It looks great. Sunday, I'll attempt to get the software loaded up on my Linux netbook, coupled to my Magellan handheld. All the charts and the software are currently on a jump drive.
I'm very excited about getting a working chartplotter on the cheap.
Water is Life
  #14 (permalink)
Old 01-29-2010
Sea Slacker
Thanks much!
I avoided making any direct announcements, but now that the topic is up - I'd like to mention that our Linux version is now fully up to date and has a complete set of features, on par with Windows and MacOS. All those interested in using Linux based system for navigation are invited to try it out.
  #15 (permalink)
Old 01-30-2010
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Most of the older design instruments, aside from RayMarine, output standard NMEA 0183 information. They do make a SeaTalk-to-NMEA bridge, but it is a bit pricey. Some of the NMEA multiplexers will convert SeaTalk to NMEA in a read only mode, but I've heard it isn't as reliable as you'd probably want it to be.
RS-232 should work fine...
Try Sea Clear software...find it via Google.
For like $30 bucks - Raymarine does provide a NMEA -> Seatalk multi device. I have it on mine. If using raymarine - AIS in particular... the multi will interface laptop etc if you do it correctly and have the Raymarine (switch)... you can do it ethernet off the laptop without USb conversion devices....
-- Jody
S/V "
1983, Barberis Show 38! or
  #16 (permalink)
Old 01-30-2010
bhcva is on a distinguished road
OpenCPN
Google OpenCPN nav software
"Solitude" Caliber 40
Ches Bay
  #17 (permalink)
Old 01-30-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Just throwing this out there; Actisense makes NEMA0183 multiplexers, NEMA0183 <=> NEMA2000 gateways, and a NEMA2000 <=> USB Gateway. Learn more here
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #18 (permalink)
Old 01-30-2010
eherlihy's Avatar
Also, IIRC, NEMA 0183 is available in two flavors. One operates at 4800baud, as pointed out above. The other, NEMA 0183 HS, operates at 38400baud. There is a good paper on NEMA 0183, again from Actisense, here.
BTW - I am not affiliated with Actisense...
  #19 (permalink)
Old 02-05-2010
ActisenseTechSupport's Avatar
ActisenseTechSupport is on a distinguished road
Thanks for the plug eherlihy.
The NDC-4 has 4/5 inputs, the baud rates can be set so you can use one with AIS for example.
It has 2 outputs so you can output 4800 baud for your autopilot and 38400 to your chartplotter or PC.
Also has USB version and user configurable filtering capability.
Follow the link in eherlihy's post.
