06-29-2006
What is the question. It is pretty easy to use an NMEA multiplexer to combine the output from three instruments and a GPS to talk to a PC.
BTW, NMEA 0183 protocol is actually a RS-422, rather than RS-232 IIRC.
There are several navigation packages that are free, but none that I know of that are open source. Are you trying to run the software on Linux or Windows? The platform would help me suggest something.
There is also a very nice NMEA Multiplexer that has Bluetooth capability, which means you can use a PDA or Laptop that is Bluetooth equipped to connect, without running a wire.
