Deck reconditioning for my Tartan 30 - SailNet Community
post #1 of 3 Old 07-02-2006 Thread Starter
Question Deck reconditioning for my Tartan 30
The deck on my Tartan 30 is in need of reconditioning, including new nonskid surface. It has never been painted before.From what I've read so far the two part epoxie paint is the way to go. Should I use the same paint for both and just use the additive for the nonskid parts of the deck?
seabreeze
Dan Desjardins is offline
post #2 of 3 Old 07-02-2006
I would definitely check out whatever paint and additive you're planning on using on a piece of plywood first, to find out whether it is going to be too rough, or not rough enough a non-skid surface before actually going ahead with it.
I don't see any real reason against using the same two-part epoxy paint for both the non-skid areas and the regular deck areas, but I would also check with the manufacturer of the paint and see what they recommend.
sailingdog is offline
post #3 of 3 Old 07-03-2006
deck surface
I refinished my deck last year with a product called DURABAK(http://www.durabakcompany.com/). It uses ground rubber particles as the nonskid; I was quite pleased with the results
egood is offline
Changing mast from keel to deck step vickers41 General Discussion (sailing related) 1 04-10-2001 03:08 PM
