07-03-2006
GROCO-HF Flush-Dry Problem
I’ve rebuilt my GROCO-HF and I’m having problems with the Flush-Dry lever position.
Using the diagram at http://www.groco.net/parts/data/508.pdf , the flush lever (part 5) will not move to the flush-dry position. I did this rebuild because the gasket (part 10) wore out. The first time I replaced it, everything worked fine when pumping out the bowl and flushing water through the system. However, when I tried to operate the lever to the flush-dry position, I encountered a lot of resistance. I pushed it on over and managed to rip the gasket (part 10). When I bought another kit and replaced the gasket the lever still would not flip over to the flush-dry position. Given the cost of these kits, I’m not about to force it again!
Has anyone else run into this problem? As best I can tell from GROCO’s documentation, everything is installed correctly. With the exception that I still can’t see where the “bridge” (Part 8) goes, so it hasn’t been installed. I didn’t think that would be an issue given that the documentation says that it was added to later models. Could this be the source of my problem?
If there's a better place or forum to ask this question, please let me know.
Help!
