Keel Bolt Maintenance - SailNet Community
 1Likes
  • 1 Post By eherlihy
post #1 of 6 Old 12-28-2014 Thread Starter
Learning the HARD way...
eherlihy's Avatar
I said that I wasn't going to add to the confusion over on the Any way to check keel bolts? thread, and I won't.
However, thanks to a "Like" on that thread, I did poke my nose into the thread, and saw the following question;
Originally Posted by rbyham View Post
This being a part of the vast lack of knowledge that I have about sailboats, let me ask the question. Is there anything that an owner can do to maintain or extend the life of his keel bolts?
I'll attempt to answer that question here. Please note that I am not going to get into cast iron, or encapsulated keels. I am also not going to go into why I believe that sistering keel bolts is NOT the way to go. I did that in the other thread.
Background:
For those of you that have't seen the other threads, I have based my experience on the following; When my current boat went to survey, over 4 years ago, it was discovered that the keel was loose. You can read about that discovery here: A wet bilge is MORE than just a nuisance !.
To make a long story short, the keel bolts were shot. There was no evidence, other than some moisture in the bilge every time that I looked at the boat. This is what the keel bolts looked like from the bilge;
and this is what the joint looked like at haulout for the survey;
Here is what the same bolts looked like this when the keel was dropped;
The keel was dropped by the yard that I had the boat hauled for the survey, and they sent it to I Broomfield and Son in Providence, RI. where they did the following;
When replacing keel bolts, we melt the lead around the bolt, remove the old
bolt (which is usually 304 SS), and replace it with a new bolt (316SS). The
lead is replaced and the keel is faired and painted around the area. [price info redacted...]
Depending upon the time of year, the number of
bolts that need replacing and how busy we are it usually takes about 4-6
weeks.[...]
The re-attaching of your keel
is usually taken care of at the boat yard, this is something that we are not
involved with at all. If you have any other questions, please feel free to
contact us.
The yard reattached the keel, by bedding it in 4200, and then wrapped the keel hull joint in fiberglass to prevent any additional moisture intrusion. When finished the keel joint looked like this;
Two years ago I had the boat soda blasted, and here is what the keel joint looked like;
All of the above has been posted in various other threads in Sailnet. Sorry if it seems redundant to the reader.
The keel joint is very solid, as I had a helmsman "discover" a ledge in the Sakonnet River, next to Gould Island at 5 knots two years ago...
NO DAMAGE!
Solution:
In order to keep the corrosion at bay, here is what I do;
  • First of all, I installed a PSS Shaft seal to keep the salt water out of my bilge.
  • I pulled the (expensive) Y-valve from the freshwater system on the boat, as that was leaking too. I replaced it with a home-built manifold of PVC and PVC ball valves (cheap and effective).
  • I also needed to fix any leaks in the coachroof (replaced both cracked and leaky deadlights, and sealed them with a non-expired tube of Dow 795 Silicone. I removed the old silicone from the coachroof with a razor, and then cleaned it off completely with MEK... I still need to seal around one of the hinges for my propane locker.)
  • I use a 4 gallon Shop Vac, which fits nicely in my laserette, to vacuum any water from the bilge. (water always seems to travel down my mast) I also leave the covers off the bilge compartment when I am not aboard. I reason that with the cover removed, there is more airflow through the bilge, and more opportunity for evaporation.
  • Every other year, pull one keel nut at a time, and clean the nut, bolt, washer, and backing plate with a brass brush. After cleaning, apply a little motor oil to the nut, and re install. I use a deep socket, and a Ĺ" breakerbar to remove the nuts. On reassembly, I use a deflection beam torque wrench torque the nut to 100 foot pounds. I usually have to play with the socket quite a bit. I turn the socket to engage with the nut, then try the breaker bar. If it doesn't engage, I remove the wrench, turn the socket 1 facet, and try again.
Here is what the keel nuts and bolts look like today (well yesterday);
You can see that I had just vacuumed water (from the incessant rain that we've had in the northeast) from the bilge just before I snapped this pic.
The last time that I pulled the nuts, the nuts, and bolts looked perfect.
I hope this helps!
tommays likes this.
eherlihy is offline
post #2 of 6 Old 12-28-2014
Re: Keel Bolt Maintenance
I like to see a lot of sealant coming out the side of the nut plates to form almost a dam. I thought the procedure was to torque the nuts only enough to make contact and fill a beveled space in the bilge around the bolt, let the sealant harden, then come back and crank to spec.
Jeanneau 54DS
Minnewaska is offline
post #3 of 6 Old 12-29-2014 Thread Starter
eherlihy's Avatar
The keel reinstall was done by "professionals" at the yard. If you look at the old pics, you will see that the sealant used in 1987 (did 5200 exist then?) was applied in the same manner.
Anyway, the point of this thread is to address what to do to maintain what you got, not how to do the installation.
eherlihy is offline
post #4 of 6 Old 12-29-2014
In your pictures, which are quite interesting thank you, it appears that the damage to the bolts was near the nuts. In the first pics it appears that there is some thread exposed above two nuts. Then in the later pics of damaged bolts it appears that the damage was more in the nut and plate region than in the structural region where sealant remains on what appears to be relatively undamaged threads.
Do you agree?
aloof is offline
post #5 of 6 Old 12-29-2014 Thread Starter
eherlihy's Avatar
The damage to the bolts (crevice corrosion) was where the nuts were. There was no damage to the bolts where they penetrated the keel stub, or the sealant (white, rubbery stuff). If I had attempted to torque, or remove, inspect and re-torque any of the 4 out of 7 damaged nuts during the survey (I recommend this) I would have discovered the issue instantly.
eherlihy is offline
post #6 of 6 Old 01-28-2015
al brazzi
I was just getting ready to create a post but I figured I may get what I need here. I seem to have the (same ?) thing but the nuts are going away and not the studs. Better than the studs of course but do I do anything other than replace the nuts. There is a little water seeping in around one of the smaller studs I haven't looked at all of them yet for water intrusion but I guess the way to fix that is from the outside as you did. Is there some reaction between the metals from different grades of SS or something like going on maybe.
If my own post is warranted please say so, I don't wish to intrude.
albrazzi is offline
Bolt on Keel champlain94 Boat Review and Purchase Forum 33 09-18-2013 03:03 PM
Keel J bolt replacement in lead keel funjohnson Gear & Maintenance 26 01-19-2013 09:01 AM
25' Catalina Keel Bolt tklinck C25 and 250 2 09-10-2011 12:10 PM
Keel Bolt question catamount Gear & Maintenance 2 06-20-2005 04:36 PM
