Hey Guys,
Thought I would post some pics of a reproduction part I made for a customer with a Ranger 37. It is the Rudder Shaft support. It is made of HDPE. The rudder shaft has worn a bit so I needed to fabricate these with a little tighter radius (about 2 hundredths of an inch). I used the CNC router and Autocad to program it and run it. I only had a 1.5 inch plastic cutter so I had to make a blocking system to line the two sides up dead nuts when I flipped them.
Thanks for checking it out.
