Red over Green mount - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 1 Week Ago
alctel is on a distinguished road
I have a 360 degree red and a 360 degree green LED series 34 lights from Aqua Signal, that I would like to use as the red over green option on my mast.
Has anyone else done this? I guess I can't use metal as it would screw with the radio reception...
I looked at the 2 180 degree lights but the only ones I could find were horrendously expensive so went with the 360s.
Owner of a 1980 36' Hunter
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 1 Week Ago
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
Re: Red over Green mount
Google:
red over green site:sailnet.com
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #3
Old 1 Week Ago
Yeah I had a look and could only find one example of the actual mounting, the rest seems to be a general discussion about what to use
  #4
Old 1 Week Ago
capta's Avatar
Master Mariner
capta is on a distinguished road
Here's how it's normally done. On one side of the mast (the fore in this case) alongside it, not above it. It's not like one can hold a perfect course and it will always be behind the mast and it shines through the sail to some degree.
The Following User Says Thank You to capta For This Useful Post:
alctel (1 Week Ago)
  #5
Old 1 Week Ago
I'll probably end up doing this rather than trying to build a mount on top of my sail. Thanks!
  #6
Old 1 Week Ago
knuterikt is on a distinguished road
The colregs found here http://www.navcen.uscg.gov/pdf/navRules/navrules.pdf Can give you some input.
Here is some quotes.
RULE 25
(c) A sailing vessel underway may, in addition to the lights prescribed in
paragraph (a) of this Rule, exhibit at or near the top of the mast, where they
can best be seen, two all-round lights in a vertical line, the upper being red
and the lower green, but these lights shall not be exhibited in conjunction
with the combined lantern permitted by paragraph (b) of this Rule.
ANNEX I
i)
(i) When the Rules prescribe two or three lights to be carried in a vertical
line, they shall be spaced as follows:
(i) on a vessel of 20 meters in length or more such lights shall be
spaced not less than 2 meters apart, and the lowest of these lights
shall, except where a towing light is required, be placed at a height
of not less than 4 meters above the hull;
(ii) on a vessel of less than 20 meters in length such lights shall be
spaced not less than 1 meter apart and the lowest of these lights
of not less than 2 meters above the gunwale;
(iii) when three lights are carried they shall be equally spaced.
9. Horizontal sectors
(b)
(i) All-round lights shall be so located as not to be obscured by masts,
topmasts or structures within angular sectors of more than 6
degrees, except anchor lights prescribed in Rule 30, which need
not be placed at an impracticable height above the hull.
(ii) If it is impracticable to comply with paragraph (b)(i) of this section
by exhibiting only one all-round light, two all-round lights shall be
used suitably positioned or screened so that they appear, as far as
practicable, as one light at a distance of one mile.”
so it's easy to do a small test to find out how far from the mast you need to place the light so you get the obstructed sector < 6 degrees
While browsing the US pdf version of the international rules i found this illustration
  #7
Old 1 Week Ago
SailRedemption's Avatar
formerly 'BoatyardBoy'
SailRedemption is on a distinguished road
I used 2 180* lights for each.. I was going to so 360* lights but I didn't want to build the pole on top of my already tall mast.
- Ronnie...on the geaux
  #8
Old 1 Week Ago
capt jgwinks is on a distinguished road
The difficulty in mounting these lights is one reason they're so rarely seen. Also remember that the red over green combo must be used WITH the side lights and stern light on deck, not instead of. That makes a minimum of four bulbs burning, and five if you have the separate side lights. All this with the engine off. You're not a sailing vessel if the engine is engaged. They might make sense on a 100 foot tallship, but I don't see any use for them on a normal sized yacht. If you want to be visible from a greater distance, go with the tricolor light at the masthead. Only one bulb burning then.
  #9
Old 1 Week Ago
With modern led lights the power consumption is reduced significantly.
boats with LOA less than 20 meters can use a combined starboard/port light.
The benefit with deck level lights combined with red/green in the mast is that you are more easily spotted both short and long distance.
You can off course alternate between deck level and tricolor but not both at the same time..
You may post attachments
You may edit your posts
Red over Green vs Tricolour alctel Gear & Maintenance 11 3 Weeks Ago 03:17 PM
Red over Green Navigation Light johnnyquest37 Gear & Maintenance 49 12-04-2014 03:25 PM
Red / Green Running Light Wiring wsmurdoch Pacific Seacraft 6 06-21-2014 12:11 AM
Red Over Green pvanv1 Gear & Maintenance 28 12-19-2011 01:39 AM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 01:32 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
