top side boat paint - SailNet Community
 1Likes
post #1 of 23 Old 07-18-2006 Thread Starter
chuckg5's Avatar
top side boat paint
Does anyone know the name of a paint I read about in a sail mag
that's made in the Netherlands call epiphoses---something like that,
it could be bought up in Thomaston, Maine. Its advertised as the shiniest, smoothest, ect. boat paint? I'd like to find it. I have to paint a 1980 vagabond 42 ketch's topsides an that looked mighty fine.
thanks!
chuckg5 is offline
post #2 of 23 Old 07-18-2006
Surfesq's Avatar
Dude...Vagabond 42 Ketch? Righteous boat. I have a Seawolf 41 Ketch.
This is a topic that is near and dear to my heart because I am in the process of re-doing my boat. The brand is Epifanes. They make a fantastic varnish. I am not familiar with their paint but I would love to know how it works for you. I am considering using Interlux Perfection.
Here is a link to the Epifanes site:
http://www.epifanes.com/
Surfesq is offline
post #3 of 23 Old 07-18-2006 Thread Starter
chuckg5's Avatar
thanks for quick reply
surfer
that links lead me to the thomaston, Maine supplier, thanks!
I emailed them to ask what would be the best method to repaint. Some previous own had brushed paint over the whole topsides, (the decks - teak)
an it now looks terrible. powdery, uneven, bumpy, dirty white with mildew growing in the visible brush strokes. Its insulting to this beautiful lady of a boat.
chuckg5 is offline
post #4 of 23 Old 07-18-2006
Surfesq's Avatar
Its funny, I have been trying to get this topic going for a while so I am glad that I finally found someone else who is going to give it a go.
The previous owner brushed the cabin on my boat. It can look really bad if it is not done correctly.
But like the epiphanes, awlgrip and Interlux all claim to work well with rolling and tipping.
I am personally going to use a gravity fed sprayer. You need to know that it is a dangerous product and you have to take serious precautions like breathers, suits, etc. But it can be done. Plus the advantage of spraying is that you can knock out the hull in three days!
Surfesq is offline
post #5 of 23 Old 07-19-2006
CBinRI's Avatar
Epiphanes is top notch varnish if applied properly. I don't know anything about the paint, however.
CBinRI is offline
post #6 of 23 Old 07-19-2006
moderate?
camaraderie's Avatar
Chuck... with such a nice boat, I would suggest you use a 2 part polyurethane solution either from epifanes or awl grip. Given your description of the current topsides you will need to put in a lot of labor before you ever touch the paint sprayer. Sand and fair the surfaces using a mfr. recommended filler to smooth things out. Clean hull thoroughly with drying agent/solvent to remove all traces of dirt/grit/wax etc.
Tape and protect all non-paintable surfaces and cover the boat or move indoors to prevent dirt/dust/insects and wind blown debris from marring your surface. Then do a primer coat for good adhesion and sand out and remaining blemishes you spot. That is 95% of the work. Now you are ready to apply your new paint for an hour or two! Be sure you know what you are getting in to or you will not get good results regardless of the product you use...I would estimate at least 2 full workweeks in prep for your size boat.
BTW... I've had excellent results with AWLGRIP2000 both initially and over time.
ChasingBlueSky likes this.
camaraderie is offline
post #7 of 23 Old 07-19-2006
Surfesq's Avatar
Camaraderie: I was serious about using awlgrip but it is very expensive. (They recommend spraying outside incidentally). The Interlux Two Part Perfection is allegedly just as good and durable and is significantly less expensive. I am going to give it a whirl.
Surfesq is offline
post #8 of 23 Old 07-19-2006
resdog's Avatar
camaraderie is right on. Prep is where a good paint job starts and is the biggest and most important part of the job. You can apply paint that costs $1000.00 a gallon and it will still look like poop if the prep isn't done.
I've sprayed Imron on a couple of boats and it's tough as nails. All of the 2 part paints with catalysts and hardeners are not good for your respiratory system and should be used with care and the proper safety equipment.
resdog is offline
post #9 of 23 Old 07-19-2006
Ronbye's Avatar
We had a discussion about painting topsides recently in another thread. In that tread I discussed how I had successfully painted my Rival 32 using Perfection paint and how I did it. I also posted in my photo gallery before and after pictures of the boat. Rolling and Tipping worked for me and it was my first time.
Ronbye is offline
post #10 of 23 Old 07-21-2006
mikehoyt's Avatar
A COUPLE OF THINGS I LEARNED
Hi.
There
mikehoyt is offline
Seakindly Boats vs.the rest rmf1643 Boat Review and Purchase Forum 14 04-10-2013 03:26 PM
Boat Insurance DonQuijotedelMar General Discussion (sailing related) 1 11-20-2010 01:37 PM
Pleasure boat insurance in Spain DonQuijotedelMar General Discussion (sailing related) 0 07-07-2006 03:56 PM
Boat Insurance perils in Spain and elsewhere in Europe. DonQuijotedelMar General Discussion (sailing related) 0 06-17-2006 01:04 PM
Boat Insurance in Spain. DonQuijotedelMar General Discussion (sailing related) 0 06-17-2006 07:55 AM
