-   -   Cat30 Exhaust riser blew up - Engine won''t start (http://www.sailnet.com/forums/gear-maintenance/1839-cat30-exhaust-riser-blew-up-engine-wont-start.html)
E_N_Z_O 07-31-2001 10:28 AM
Cat30 Exhaust riser blew up - Engine won''''t start
Hi everyone,
I am curious if anyone could give me some advice, here is the situation to date
Exhaust elbow blew up/engine won''t start
Submitted by Rick of Massachusetts on 07/15 at 06:56AM regarding Catalina 30.
Yesterday we found that our exhaust elbow leading from our Atomic 4 (gas) to the water lift was corroded beyond use when it blew up and started spraying water into the engine compartment. We turned the engine off and then restarted it. The engine started fine but the water was spraying out of a quarter sized hole. We immediatly stopped the enginge and wrapped a rag and duct tape around it so we could get back to the mooring. Needless to say, the engine now would not start. Today will be spent locating fixit supplies for the pipe. Does anyone have any ideas why the engine wouldn''t start? My main concern is that water has a way to back into the engine. Please allay my fear of a rebuild.
Any ideas?
It still won''t start...
Submitted by Rick on 07/23 at 07:54AM regarding General_interest.
OK, I spent the weekend trying to get my A4 started again. I can''t.
I am sure it is something very small that I am overlooking. Here''s what I did. Drained the aqualift by taking out the screw in the bottom. Got all the exhaust pipe I needed and installed it. Cranked the engine. Nothing.
In fact, water again backed up the exhaust pipe at least to the exhaust manifold. When I crank the motor no water exits the exhaust out the back. Can a muffler get clogged with corrosion from a bad pipe? If so how can I get it unclogged?
I have spark. I have compression. There is at least some gas as I can smell it once it floods and also when I take out a spark plug. I have tried cranking with the water intake closed and open. I have taken the exhaust pipe off the manifold and tried again. I do get vapor that smells like gas out the manifold in that case. I tried all of this until the batteries discharged.
What am I missing?
No-going saga of Exhaust riser blow up :(
Submitted by Rick of Salem on 07/31 at 07:18AM regarding General_interest.
OK heres what happened this weekend. I installed new plugs and did everything everyone has suggested. When it came time to crank the engine the batteries where of course dead. No problem I used the portable battery I got for just such a day. When I hooked it up (positive to positive, negative to negative) just like I had it the weekend before and cranked the engine,CLICK. No starter except for the first click of it engaging. To make things worse SMOKE coming off the starter wire and the plastic on the battery terminal was melting. When I turn the power off at the main the starter again makes a sound. Mind you, this is exactly the same set up I had the week before when it cranked over just fine but didn''t start. I suspect the lack of battery allowed the solenoid to switch but wasn''t enough to turn the engine.
Of course at this point the First Mate insisted that a call to a mechanic was neccesary. Today I got the call back. He wants me to realize that I need a new engine! Something in diesel at $5000.00.
Does the story so far sound like a wrecked engine? Has anyone ever got water back from the muffler and lived to tell?
RichH 07-31-2001 03:48 PM
If water has gotten into the engine ....... Immediately clean the cylinder head of debris, remove the spark plugs and squirt into the cylinders a few tablespoonsful of Marvel Mystery Oil (from an auto supply store). Squirt it in straight down and again to the portside of the combustion chamber. With the plugs out, spin the starter, let sit, spin the starter and check with your thumb to see if you still have compression.
If no compression, open the valve cover on the portside and inspect to see if the exhaust valves are stuck open (not moving when you crank the starter). If valves are stuck, fashion a ''lever'' from an old screwdriver - go into the sparkplug hole and push the stuck valve down until it hits the valve seat (bottom) - coat the valve stems with Marvel Mystery Oil and spin the starter (remove the ''lever'').. keep pushing the valves back down and wiping with MMO until free.
If you have evidence of water into the crankcase -drain and fill with MMO, crank for a few minutes but do not start and let sit a few days.... then start and run to warm WITH NO LOAD (no forward - no reverse). Replace the Marvel oil in the crankcase with 75% oil & 25% MMO.
No Atomic four is dead until the block corrodes through .... Your mechanic is salivating for a new engine job that will cost you $4-5000+++ (also needs changing the fuel tank, the propshaft, prop, the engine bed, etc etc. and you still wont have as reliable or as smooth running an engine as an Atomic-4 !!!). If you need to TOTALLY rebuild (rare) - expect to pay $2000-3000 tops. But I''d not let this particular mechanic do it - he seems a bit too "hungry" perhaps even dishonest.
You can get the Atomic-4 Service and Overhaul Manual directly from Don Moyer www.moyermarine.com - about $50.00 and worth its weight in GOLD. He also rebuilds Atomic-4s and is VERY reasonable in price. BTW - he is the world''s renown expert on Atomic-4s. ... and will discuss your ''problem'' at no charge. Perhaps he can recommend a ''good'' Atomic-4 mechanic near you - he knows most of them.
If you need additional help (assuming you can turn a wrench) join the Atomic-4 newgroup here on Sailnet. Lots of knowledgeable Atomic-4 drivers/folks lurk there.
Hope this helps. ;-)
RichH 07-31-2001 07:55 PM
If the engine has ''frozen'' because the piston rings have rusted to the cylinder walls and piston grooves, don''t despair ... do the Marvel Mystery Oil soak (plus a little "PB Blaster" mechanic''s rust penetrating catalyst - auto shop sutff) as outlined in my previous post .... and keep on attempting to break the engine free with your hand crank.... it WILL free up and will probably run just fine. Once it frees-up turn it over with the starter only .... for a while. I just hope that you haven''t waited too long to oil-soak the engine. .... your ''mechanic'' should have recommended this for you to do right away on the **least suspicion** of water intrusion into the combustion chambers.
