Water heater needed - SailNet Community
 2Likes
post #1 of 16 Old 01-25-2015 Thread Starter
Schooner Captain
UnionPacific's Avatar
Water heater needed
Seems our water heater is going out. Its now leaking inside the case.
No matter, its too large.
Looking for a small unit to replace the 10 gallon I have now.
Needs to be low priced, And small in size.
Was thinking about a 2.5 gallon home unit.
UnionPacific is offline
post #2 of 16 Old 01-25-2015
Old enough to know better
Re: Water heater needed
Well a home unit will not let you use the engine cooling circuit.
Sent from my XT1080 using Tapatalk
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #3 of 16 Old 01-25-2015 Thread Starter
Schooner Captain
Very true, but on a trade wind route, how much engine will I use?
We have a generator for battery charging, and will have solar too.
post #4 of 16 Old 01-25-2015
Skipper Jer's Avatar
Solar water heater?
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #5 of 16 Old 01-25-2015 Thread Starter
Schooner Captain
Originally Posted by Captainmeme View Post
Solar water heater?
No, The wife likes to shower indoors at the dock.
We have one for passages thou.
post #6 of 16 Old 01-25-2015
tdw
Super Fuzzy Moderator
tdw's Avatar
We've got a 50 litre (13 US gallons) and I wish it was larger. When water availability is not an issue it is nice, particularly in cooler weather to have a hot shower and five gallons is not quite enough for two.
(yes if we are away from easily available water supply we use less than otherwise and can if pressed make tank last a lot longer than two showers.)
(Original of this post said 5 gallons. Wrong. I don't know why I though that.)
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #7 of 16 Old 01-26-2015 Thread Starter
Schooner Captain
My wife is the one woman I know how takes a military shower each morning as normal.
The product of being 1 of 3 sisters? As for me, If I used 5 gallons to shower it would be a lot. This is at the dock. I would rather have one tiny heater with it cranked up all the way to 160 degrees, then a big one at a lower temp. When we practiced with a solar shower she didnt quite use 2 of 3 gallons to shower, wow!
post #8 of 16 Old 01-26-2015
BarryL's Avatar
Hey,
A few years ago I replaced a dead water heater with a Kuuma. It was the cheapest unit I could fine and it worked just fine. I sold the boat last year so I won't know how long it lasted but it seemed to be OK.
They have various plumbing options, run on 110V AC or engine heat, etc.
Kuuma Marine Water Heater - 6 Gallon
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #9 of 16 Old 01-26-2015
Old as Dirt!
svHyLyte's Avatar
In early 2013 we did rather a lot of research on this matter for friends of ours who's Raritan had given up the ghost while they were enroute to Trinidad from Martinique. The most highly rated unit we found with the longest lasting hold-over time was the SuperStor, at the time available through Defender. Defender shipped the unit to them in Trini as "Ship's Stores in Transit". With exception of the electrical pig-tails to the heater element being solid rather than stranded wire, they have been very pleased with the equipment.
FWIW,,,
svHyLyte is offline
post #10 of 16 Old 01-26-2015
Bristol 45.5 - AiniA
Let me get this clear - is the water heater for the big boat or the new dinghy?
capta likes this.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
Water Pump/Hot Water Heater/Breaker Trips DINKS14 Gear & Maintenance 5 03-10-2014 10:31 PM
Dickinson Newport Heater Valve Help needed edenrose Gear & Maintenance 6 01-21-2010 03:03 PM
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 06:01 AM
new water heater ralphmacey Announcements and Suggestions Box 6 05-26-2008 01:19 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
