Old 07-23-2006
dman is on a distinguished road
jatoba wood
What protection for exterior use can you use on this wood?
Old 10-28-2011
snook91901 is on a distinguished road
bump
Old 10-29-2011
mitiempo's Avatar
Jatoba looks like teak but does not have the oily protection from rot that teak has. Varnish, cetol etc will protect it but rot is an issue down the road that teak doesn't have.
Brian
Old 11-03-2011
Stiche's Avatar
Custom Member
Stiche is on a distinguished road
Jatoba (aka Brazilian Cherry) is an absolutely beautiful wood, and is very dense. As a matter of fact, I'm typing this message on my custom Jatoba wood desk
I haven't used Jatoba on my boat. I'm using Phillipine Mahogany, African Mahogany, and teak (just for the hand rails)....but...
Jatoba is very resistant to rot and insects. It is susceptible to marine borers (like Shipworms, Teredoes, or Gribbles). Since you're not building pilings out of the wood, you're going to be OK here Also, marine borers are saltwater, so if you're a freshie, you're OK. Lastly, any surface barrier will protect the wood from a marine borer...so likewise, you're fine there.
OK, coverage...
Use a clear varnish with or without UV inhibitors (Jatoba turns a beautiful dark red when it is exposed to sunlight, if it's not dark red already; and this change happens within days outdoors.) I used Z Spar Flagship varnish with excellent results on my exterior teak and mahogany, but never tried it on Jatoba.
If you want to use some for interior work, go with varnish or polyurethane. I use Minwax Wipe-on Polyurethane (Gloss) exclusively in my interior. Jatoba will take about 6-8 coats for a nice glossy, but not the super-glossy varnished look. Wipe-on poly, unlike its brush-on cousin, is very easy to apply.
I would not recommend Cetol on Jatoba without doing some test areas (and then only Cetol Light) only because Cetol has pigments and I believe it is a federal crime to cover up Jatoba.
Stiche
"Sattar" Cal 25, #256
Is cruising only for my parents? Newport41 General Discussion (sailing related) 80 07-24-2006 09:49 PM
Soft/Rot Wood on ply in bilge. Rasputin General Discussion (sailing related) 3 06-22-2001 05:01 AM
Soft/Rot Wood on ply in bilge. Rasputin Gear & Maintenance 3 05-11-2001 10:30 PM
HERON BOND WOOD varnishing twotone105 Gear & Maintenance 0 01-29-2001 09:20 PM
