Is rusty metal infectious?? - SailNet Community
 12Likes
post #1 of 22 Old 01-27-2015 Thread Starter
MarkofSeaLife's Avatar
Dock
This may be the worlds most stupid question....
Hypothetical.
Is rusty metal infectious? For example if I have a bit of chain where the galvanising has completely gone and the chain is rusty and I twist it with a bit of new chain so its touching, will the new chain rust faster?
Mark
zeehag likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #2 of 22 Old 01-27-2015
Land lubber
Re: Is rusty metal infectious??
no
MarkofSeaLife likes this.
ianjoub is offline
post #3 of 22 Old 01-27-2015
snake charmer, cat herder
zeehag's Avatar
shouldnt, unless it is pooped on by a hoorse then it will get tetanus.
rust5 no dont spread.
i vinegar my chain after it is out of sea water.. then fresh rinse, even when i stuff it into anchor chain locker... then i havent the stink fresh dying sea life makes and not the rust... seems to be working....
formosa 41, cruising tropics
zeehag is offline
post #4 of 22 Old 01-27-2015
Caribbeachbum's Avatar
No more so than throwing (cold) ashes on a tree would cause it to catch fire. This is literally true -- FeO2 (iron(III) oxide aka rust) is just burned iron. But it's a slow burn man, a slow burn.
Caribbeachbum is offline
post #5 of 22 Old 01-27-2015
aeventyr60's Avatar
Rust never sleeps, so i'd say it is highly contagious. Better get WHO on that chain pdq.
westsailpatti likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #6 of 22 Old 01-27-2015 Thread Starter
Dock
What?
Sea Life
post #7 of 22 Old 01-27-2015
aeventyr60's Avatar
Originally Posted by MarkofSeaLife View Post
What?
https://www.youtube.com/watch?v=e0YFJvWmoes
Seems to me rust spreads pretty easy...
post #8 of 22 Old 01-27-2015
OldEagle's Avatar
The rusting is not "contagious"
The rusted links are almost certainly more abrasive than clean galvinized links--so, working back & forth against the new links, they could wear off some of the galvinized coating on the new links and thus allow faster rusting to occur.
Solution: "polish" up the connecting old link. If you're concerned about it.
OldEagle is offline
post #9 of 22 Old 01-27-2015
travlin-easy's Avatar
Contrary to poplar belief, rust cannot cause any disease. You could eat rust and nothing would happen, but I'd bet it's not real tasty.
When I worked in medicine the fear was that if you were cut with a piece of metal, you would contract tetanus - nope, never happen. However, during my 15 year tenure in the field I saw three cases of tetanus. One was caused by a rose thorn, another by a trash collector being cut with a shard of glass, and the third, we never knew the origin. All three died within two weeks.
Gary
travlin-easy is offline
post #10 of 22 Old 01-27-2015
Cruising at a snail pace
I actually feel that if the chains are in contact and wet that corrosion will be faster as the zinc in the good chain tries to protect the old chain.
TQA likes this.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
Rusty Rode Gladrags1 Gear & Maintenance 3 04-19-2014 02:48 PM
Rusty Rigging pinckney54 Gear & Maintenance 2 06-24-2009 11:06 PM
Restoring shine to metal parts (cleats, port hole metal) saurav16 Gear & Maintenance 23 11-19-2008 05:42 PM
Rusty seacock patrickbwells Gear & Maintenance 11 03-21-2007 03:48 AM
Rusty Rudder bhmcp Gear & Maintenance 3 11-10-2004 07:26 PM
