Old 07-24-2006
aruggiero is on a distinguished road
New stove
We purchased a new lpg stove for our boat and we are getting ready to install it. The one that came with our boat didn't have an oven. The cutout for the stove is exposed fiberglass in the back. I don't know if it was that way originally or not - do we need to put some type of insulation or protect the fiberglass back there before we install the stove?
Thanks - I don't know what we would do without all the helpful advice we have received from this site!!!
  #2
Old 07-24-2006
capn_dave's Avatar
Seinor Member
capn_dave is on a distinguished road
You should be ok
without insulation behind the stove. Thar is if it is a stove designed for boats.
You said it was a new stove? Did it not come with instructions for mounting? The only thing I would ne concerned with, if it is gimbaled is there enough clearance so it can swing without hitting the hull.
Fair Winds
Cap'n Dave
  #3
Old 07-24-2006
We bought the stove used so there are no installation instructions with it. It is a marine stove and it is gimballed. The original cutout was for a 3-burner lpg range and the stove we just bought is actually smaller than the original.
Thanks!
  #4
Old 07-25-2006
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
"We bought the stove used so there are no installation instructions with it."
If the manufacturer is still in business, they can give you the instructions. At the least I'd make sure it is installed with some stops so it CAN'T hit the hull no matter how hard it swings.
You may post attachments
You may edit your posts
Hillerange/ marine stove Martindk Gear & Maintenance 8 03-13-2011 01:00 PM
marine stoves HeidiMills Gear & Maintenance 3 07-27-2001 04:05 AM
marine stoves HeidiMills Gear & Maintenance 0 07-13-2001 07:11 PM
Cabin Heaters PatWatt Gear & Maintenance 5 12-18-2000 04:00 PM
SEO by vBSEO 3.6.1
