07-30-2006
BTW, while you're rebedding the hardware, it might be worth checking to see if the hardware was properly installed, with solid epoxy potting for the fastener holes and around any through deck openings. If this was not done, it might be worth doing, as it will help prevent water from entering the deck core (if you have a cored deck) and help prevent the core from rotting or delaminating.
