Head recommendations - SailNet Community
post #1 of 6 Old 07-29-2006 Thread Starter
I am installing a full MSD system on my new boat (has a porta-pottie currently). I am looking at getting a Raritan PHII manual toilet and would like to hear what others think good/bad about this unit and other brands/models they think would be better.
SteveCox is offline
post #2 of 6 Old 07-29-2006
Wandering Aimlessly
PBzeer's Avatar
Vis-a-vis your holding tank question, you might want to look into composting heads.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #3 of 6 Old 07-29-2006
Thoughts on the Raritan PH11
Steve, My H37.5 came from the manufacturer with a Jabsco. After 10 years and 3 new units and nothing but trouble I finally made the move to the PH11. Like night and day. Best addition I have made thus far.
Retention is offline
post #4 of 6 Old 07-29-2006
Steve, My H37.5 came from the manufacturer with a Jabsco unit installed. After 3 new units and nothing but trouble I finally made the switch to the PH11. What a difference. Best addition to the boat I've made so far.
post #5 of 6 Old 07-29-2006
moderate?
camaraderie's Avatar
Steve...we have 2 PHII's onn our boat which is full time livaboard and I am happy with them. They do need to be rebuilt occassionally and the usual routine of monthly vinegar rinses followed by mineral oil to keep things lubed up helps delay the inevitable. The good thing about them is that they are reliable and parts are available almost everywhere if you are cruising.
The other head that gets rave review from full time cruisers is the Lavac which uses a pump to create a vacuum to draw in water and eveacuate the bowl which depends on the seat seal to create the vacuum and thus no worries about joker valves etc.
If you DO get the PHII...they have it here and the rebuild kit (get one before you need it!) for a LOT less than your local West Marine!
camaraderie is offline
post #6 of 6 Old 07-30-2006
Might also want to look at the Lavac heads. They seem to have less maintenance problems compared to many other heads. Also, Lavacs tend to use less water per flush, and may allow you to go longer between pumpouts.
sailingdog is offline
tiller head for a Galilee? TominBC Gear & Maintenance 2 12-01-2012 09:15 PM
Head Sail repair/replacement wsutton Gear & Maintenance 0 07-12-2006 08:01 AM
Head Sail repair/replacement wsutton Gear & Maintenance 0 07-12-2006 08:00 AM
Konvert a Head info requested Jeff Hawes Gear & Maintenance 0 06-24-2006 02:22 PM
Head overflows when heeled Sloop23_417 Gear & Maintenance 2 06-18-2001 10:28 AM
