Jib Furl Rigging - SailNet Community
post #1 of 3 Old 07-30-2006 Thread Starter
Jib Furl Rigging
I have just purchased a boat with a jib furl and the furl rigging is not set up properly. I do not have prior experience with jib furls. Many of the lines on the boat were altered when it was storm tied during the busy hurricane season last fall.
Can anyone recommend how I can learn how to re-rig the furl or offer suggestions on how to do it?
This is how it was rigged when it was purchased:
Hierax is offline
post #2 of 3 Old 07-30-2006
Basically, the furling line that wraps around the drum needs to be set for the size of the headsail you're planning on using. On some units the turns are clockwise, on others counterclockwise.
The furling line should go through some blocks or fairleads and lead back to the cockpit.
The head of the sail attaches to a swivel, which the jib halyard brings up the foil, to the top of the headstay. The jib should have a boltrope or wire luff that feeds into a groove on the foil. The tack of the sail should attach to a shackle just above the furling drum you have in the photo. The clew of the sail attaches to jib sheets as normal.
After raising the jib/genoa, you furl it by putting a light amount of tension on the jib sheets and then pull in on the furling line. To unfurl, you do the reverse—put a bit of tension on the furling line and pull on the jib sheets. Try to keep the furling line under tension so you don't end up with over-rides or bird's nests on the drum.
You can probably find this information out from the manufacturer's website. Any questions??
sailingdog is offline
post #3 of 3 Old 07-31-2006
Cruising Design has been producing reliable furlers for some time, and they are still in business, and can probably answer questions for you as well. From the pictures, it looks to me like a piece has broken off the drum--might be worth replacing to ensure it holds the line in place where you want.
good luck!
Frank.
FrankLanger is offline
dousing a hanked jib terryny Seamanship & Navigation 17 01-16-2003 05:19 AM
How much can you furl a headsail swg Seamanship & Navigation 9 05-02-2002 09:04 PM
needs jib BobCambell Learning to Sail 1 08-17-2001 09:03 AM
need to raise the Jib. glowworm Gear & Maintenance 4 04-10-2001 11:46 AM
Kells 23 rigging Skegger2 General Discussion (sailing related) 0 01-05-2001 09:28 AM
