Hillerange Seaward Princess Hinge Repair - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree1Likes
Old 02-16-2015
JimMcGee's Avatar
JimMcGee is on a distinguished road
I have a two burner Hillerange / Seaward Princess range (#2172). One of the hinges has been loose since we got her. If you want to use the oven you have to tug the door upward slightly when you close it to get a good seal.
It "feels" like a loose mounting bolt, but my concern is the pivot hole in the spring arm assembly may be rounded out from use.
The good news is I've gotten far enough into my "to-do" list that I can deal with "annoying little things". The bad news is I'm not sure I can still get parts for this range and it looks like I'm going to have to remove it completely and do a lot of disassembly to get to the hinge (which is why I've been living with it).
Before I dive in I was wondering if anyone here has done this repair and if there's any info you can share?
Thanks in advance,
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 02-17-2015
JimMcGee's Avatar
Re: Hillerange Seaward Princess Hinge Repair
Thanks in advance,
Jim
. . . Bump . . .
  #3
Old 02-17-2015
deniseO30's Avatar
Oday30!
photo?
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
My boat is for sale!
  #4
Old 02-17-2015
Captainmeme's Avatar
Captainmeme is on a distinguished road
I wonder if the oven door on this range is similar to doors on house ranges. If that is the case then maybe a visit to an online appliance repair forum might get you some answers.
Also have you looked around for a manual? I found one here, http://www.marlow-hunter.com/export/...ss%20Stove.pdf
From the exploded (not a good thing to say when discussing propane stoves on a boat )
parts view it looks like the hinges can be replaced with out removing the stove from the counter. If its like a home range the door might just lift off.
Nor'sea 27
  #5
Old 02-18-2015
JimMcGee's Avatar
Originally Posted by Captainmeme View Post
...From the exploded (not a good thing to say when discussing propane stoves on a boat )
Hmm, never tried lifting off the door. I have the original manual for the oven and it has an exploded view that's not very helpful. When I originally looked at this (which was admittedly quite a while ago) it looked like the unit had to be taken out and the side panel and possibly a bottom panel removed on a 20 yr old range to get access. In other words a PITA job; and whatever parts I need will have to be special ordered if I can get them at all.
I was kind of hoping this was a common problem and someone would chime in with with a shortcut or a quick fix. Guess I'm not going to get that lucky
I'll tackle this one once it warms up a bit, still too damn cold here.
  #6
Old 02-18-2015
JimMcGee's Avatar
Originally Posted by deniseO30 View Post
photo?
Sorry no photo. But it's pretty much the standard 2 burner Seaward Princess range you find on most boats...
  #7
Old 02-18-2015
SVTatia is on a distinguished road
Check Sure marine.
Could you identify your parts in the diagram?
If so, scroll down the page for the part number.
Sure Marine Service, Inc. | Seaward Replacement Parts for Models 2172 & 2372
The Following User Says Thank You to SVTatia For This Useful Post:
JimMcGee (02-18-2015)
  #8
Old 02-18-2015
SJ34 is on a distinguished road
+1 Sure Marine. They service these ranges. Be careful how deep you go though. I could have bought a new unit with the money I spent replacing all the valves, t-couples etc.
  #9
Old 02-18-2015
JimMcGee's Avatar
Originally Posted by SVTatia View Post
Check Sure marine.
SVTatia, thanks for posting this !
The exploded diagram on Sure Marine's web site is the same as the one in my manual. I'm guessing from the way the door moves it's either the hinge assembly or the spring arm pivot.
I'd stopped by a local parts dealer listed on Seaward's web site and he said the part aren't available anymore which seemed odd given how many of these ovens are out there.
  #10
Old 02-18-2015
I think you are referring to parts nos. 22, 23 and 24 on the diagram, which are available thru Sure Marine... Just scroll down from the diagram page.
You may post attachments
You may edit your posts
Unclogging Hillerange (Seaward) 2101 alcohol stove L124C Gear & Maintenance 1 01-21-2014 03:53 PM
Repairing a Hillerange oven in Annapolis? Jiminri Gear & Maintenance 15 08-05-2013 08:34 AM
Hillerange Alcohol Stove Fittings halyardz Gear & Maintenance 22 04-08-2013 05:17 PM
Hillerange/ marine stove Martindk Gear & Maintenance 8 03-13-2011 01:00 PM
Hillerange Parts, trying to make a decision... T37Chef Gear & Maintenance 10 10-10-2008 11:17 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
