Compass and Electronics - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree5Likes
Old 6 Days Ago
Dave_E's Avatar
Dave_E is on a distinguished road
Hi All,
I am installing my new plotter next month. Here's the deal. My compass is installed, compass swing every year, no problems with the compass. When I set the plotter where I'd like it to be (permenantly) I get some compass movement (2-4 degrees). My question is can I mount the plotter and then re-swing the compass for acuracy, knowing that I just threw it out of whack with the plotter placement? I don't see why I couldn't... might have to use a correction card more than I'd like.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 6 Days Ago
Frogwatch is on a distinguished road
Re: Compass and Electronics
Whats causing the swing? It is probably the DC input. Maybe use twisted dc input wires.
MarkofSeaLife likes this.
  #3
Old 6 Days Ago
jerryrlitton's Avatar
jerryrlitton will become famous soon enough
Send a message via ICQ to jerryrlitton Send a message via MSN to jerryrlitton Send a message via Yahoo to jerryrlitton Send a message via Skype™ to jerryrlitton
Originally Posted by Dave_E View Post
Hi All,
Dave
What you are refering to is compass deviation. Sure, re swing it and if you want to do it right is get a deviation card to mount close to your compass (because you will never get all the deviation out). The card will have every 30 degrees the course you want to the course you steer. For instance 030 degrees steer 032. In addition when you are swinging turn on all the electronics you normally have in operation such as radar, depth sounder and the like. They all can make a difference. Just for grins turn on the auxiliary, the alternator if it is not filtered/shielded may also show some deviation. Also the big belt buckles and swords will cause deviation....
Dave_E likes this.
"Duty, that grim demanding bitch, come to call with all her nagsome sisters, would never give a man a moment of his own."
A Kings Trade
Dewey Lamdin
s/v Temptation
Islander 44
  #4
Old 6 Days Ago
celenoglu's Avatar
celenoglu is on a distinguished road
Deviation is the result of electricity passing through the wires. Even if you swing the compass the error will deviate according to device being running or turned off. To have a healthy angle after swinging the compass the plotter should always be running.
Dave_E likes this.
  #5
Old 6 Days Ago
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
A lot of interference from chart plotters is caused by the magnetic door for the sd card. Usually this is located on one end of the plotter. If you install the plotter keeping the door 11" away from the compass you should have less deviation.
Tod
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
  #6
Old 6 Days Ago
hellosailor's Avatar
I've mislaid my Kraken!
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
RTFM.
Does the manufacturer say anything like "DO NOT INSTALL WITHIN 36" OF ANY COMPASS" or something like that?
Some electronics emit magnetic fields, and they're not always consistent.
  #7
Old 6 Days Ago
capta's Avatar
Master Mariner
capta is on a distinguished road
Though we have a compass under our plotter at the helm, we rarely use it when the plotter is working; the plotter should give you a pretty accurate course, if you need one. We find ourselves either sailing on landmarks or towards a way point, using the chartplotter.
If the chartplotter failed and you needed the compass, perhaps it would be best to just remove the chartplotter when you need the compass, and not adjust it for the plotter, especially if the deviation changed depending if the plotter was on or off.
facebook.com/svskippingstone
  #8
Old 6 Days Ago
Any ferrous metal close to a compass can cause some deviation. You don't have to have electricity.
A Kings Trade
Dewey Lamdin
s/v Temptation
Islander 44
  #9
Old 6 Days Ago
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
I think Froggy gets the teapot or whatever the prize is. That a simple no cost trick to try that may do the, ummmm, well, trick.
If that doesnt work then I agree with CaptA: who the hell uses a compass??
Sea Life
Notes on a Circumnavigation:
  #10
Old 6 Days Ago
How about when the chart gives bearings from two or more known points to fix a hazard in the water? You had best have an accurate or swung compass to fix that hazard? That's a problem when people put too much faith in the electronic God. We have them in aviation too.
A Kings Trade
Dewey Lamdin
s/v Temptation
Islander 44
You may post attachments
You may edit your posts
New Electronics rcnight Electronics 1 4 Weeks Ago 08:50 PM
Old electronics? justsammer Gear & Maintenance 11 07-30-2014 06:02 PM
New Electronics Arclight Electronics 5 08-10-2010 07:32 PM
Electronics Darco1 Cruising & Liveaboard Forum 2 04-08-2005 04:20 PM
ELECTRONICS INSTALLER SHIMSHON General Discussion (sailing related) 0 02-19-2001 11:32 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
