One-Piece Hatch Board - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 2 Days Ago
Christian Williams is on a distinguished road
The one-piece plywood hatch board, replacing four pieces of teak, is a big improvement. But it might be even better in plastic. You just need a handy place to put it. If it fits in the seat locker, home free.
One-Piece Hatch Board; Tides SailTrack; HX gaskets - Blogs - EY.o Information Exchange
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 2 Days Ago
capta's Avatar
Master Mariner
capta is on a distinguished road
Re: One-Piece Hatch Board
I also hate hatch boards and went a slightly different way, using Starboard. It just slides in the hatch board slots and is held in place by two brass angles. It is very strong, yet removes in just a few seconds.
It took less than a day to build and if memory serves only about a c-note in materials.
  #3
Old 2 Days Ago
chuck53 is on a distinguished road
Even better...doors on lift off hinges. When I want to keep the boat closed up, it's easy in and out and if I want to keep the boat open, I take off the doors and stow them below.
Catalina 34
  #4
Old 2 Days Ago
CaptainForce's Avatar
CaptainForce will become famous soon enough
We still keep our original crib boards for heavy weather, but we normally keep a more decorative one piece crib board.
We find it easy to enter and leave our companionway without removing this piece of stained glass sandwiched in polycarbonate sheets, though it easily stows in a slot next to the steps to our main cabin when we remove it.
Take Care and Joy, Aythya Crew
  #5
Old 2 Days Ago
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
We have a one piece board and am relatively happy with it but I would like to somehow come up with a hinged insect screen. Variation on CaptA's idea but with a netting insert would seemingly be the answer.
Andrew B
"Said Hamlet to Ophelia, I'll draw a sketch of thee.
What kind of pencil shall I use? 2B or not 2B?” Spike Milligan
  #6
Old 2 Days Ago
aloof is on a distinguished road
Don't most of us need two piece hatch boards so we can climb in and out in rough weather? Looks vital with the cockpit in the photo.
Any clod can have the facts, but having opinions is an art. — Charles McCabe
  #7
Old 2 Days Ago
tdw's Avatar
tdw tdw is offline
Doesn't the hinged board answer that question ? Presuming of course you have a reasonable bridge deck or lip.
Somewhat scrappy pic but as you can see the lip on our girl is a good height.
Andrew B
  #8
Old 2 Days Ago
Old enough to know better
miatapaul is on a distinguished road
I was on a Lancer 36 and one of the things I liked was it had 3 part hatch boards. There was a 6 inch hatch board that was hinged on the bottom so it swung down and above that two doors that swung out. So you could lower the lower board and have it out of the way, but if it was just a bit snotty out you could flip it up and it had barrel latches to keep it closed but could still get over it easily. then if it got worse close the doors. Only thing was the doors did not seem very secure. If it were my boat I would likely make a single panel to slide in to close it off more securely. But it is not like it was an offshore boat. I thought it was a pretty good compromise.
  #9
Old 2 Days Ago
PaulinVictoria's Avatar
Remember you're a womble
PaulinVictoria is on a distinguished road
I have a one-piece that stores neatly in two little brackets in the lazaratte.
Orange Crush
1974 C&C27 MkII
  #10
Old 2 Days Ago
DonScribner is on a distinguished road
Our Lancer 25 came with three pieces of plastic (poly or acrylic, not sure) that were cut at a bias so when stacked in place, water would always shed outward. But being old, crazed and brittle, I needed to replace. I settled on three pieces of 1/4" bronze acrylic, again cut at a bias. I used 3M VHB tape to attach PVC "living hinge" to the inside. The assembly is watertight and smooth. Since the Admiral may need to change inside while I entertain, I sanded the inside surface (before assembly) with an orbital sander. If you press your face (or other body part) against the surface, you can see it. But 5 inches away, it's just a blur at best. And when I have to stow it, I pull up, fold towards the middle and stuff it below, neatly tucker beside the companionway stairs. BEst of all it looks "wick'd pissah!"
You may post attachments
You may edit your posts
Can anyone tell me what this piece is used for? Jhiggy Learning to Sail 7 09-01-2013 03:22 PM
Your ONE piece of wisdom... MedSailor General Discussion (sailing related) 150 06-05-2012 04:32 AM
Hatch board replacement with saloon door jbrockpiano Gear & Maintenance 7 05-18-2010 10:44 AM
Hunter 28 really a piece of ****? TheSeaPenguin Boat Review and Purchase Forum 16 10-03-2009 01:03 AM
Two piece mast? L124C Sailboat Design and Construction 3 10-20-2007 11:05 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
