Choosing the right metal - SailNet Community
 3Likes
post #1 of 16 Old 03-25-2015 Thread Starter
Hope I can get some help here. I need to replace the attachment on my Pearson's swing keel. The old one has corroded to almost nothing. It may be nearly 50 years old. It looks like it is probably some kind of bronze. It's only about 1/8 inch thick at best and in some places is almost paper thin. The board weighs maybe 200 lbs.
I can get 220 bronze sheet cut to size and would only have to drill a couple of holes to make the replacement. Or I can get aluminum bronze in 1/4 inch bar stock that could work and I think is more corrosion resistant than the 220 in seawater.
If any of you guys can tell me which way to go, I will really appreciate it so I can get this repair done and get this boat back in the water.
I've tried to get some info from a thread in the Pearson forum, but maybe here will get more exposure.
CLOSECALL is offline
post #2 of 16 Old 03-25-2015
Re: Choosing the right metal
Any chance of a picture or a drawing? not quite seeing what exactly you're needing to replace (but confess lack of familiarity with that boat/system)..
Faster is offline
post #3 of 16 Old 03-25-2015 Thread Starter
How's this. This is not mine, but just like it (except this one is in good shape).
Faster likes this.
post #4 of 16 Old 03-25-2015
Delta-T's Avatar
I would go with 316 stainless, and bolts, the cable should be 316 SS and the swage should be zinc coated copper. At least that is what lasted 25+ years before I changed it out for new last year. My details can be found here
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #5 of 16 Old 03-25-2015
Senior Moment Member
SloopJonB's Avatar
I'd use the most corrosion resistant bronze flat bar I could get. I prefer bronze to S/S underwater if I have the choice.
Frankly though, I don't think it much matters - I'm sure many boats have had fittings like that made from galvanized iron or steel.
SloopJonB is offline
post #6 of 16 Old 03-25-2015
Thanks Closecall.. that should be easy to fabricate once you choose your material!
Faster is offline
post #7 of 16 Old 03-25-2015
RichH's Avatar
Try drmarine.com for a replacement. Ask for Rudy.
You'll need VIN, year and model.
RichH is offline
post #8 of 16 Old 03-26-2015
Delta-T's Avatar
The cable is SS and if in contact with brass in salt water, the SS will win out as you can clearly see in my thread.
Eric
Delta-T
Delta-T is offline
post #9 of 16 Old 03-26-2015
Delta-T's Avatar
The problem here is abrasion in the cable tube. Why change something that is proven to work.
Edit: My bad, I thought you were suggesting Dyneema. I miss read that.
oysterman23 likes this.
Eric
Delta-T
Delta-T is offline
post #10 of 16 Old 03-27-2015 Thread Starter
I believe I'll go with stainless. The rest of the system is stainless so that makes sense. Also stainless is more readily available. Thanks for the input.
Where did this metal come from? L124C Gear & Maintenance 0 03-21-2013 11:54 PM
The Metal Yacht kwaltersmi General Discussion (sailing related) 10 01-22-2013 05:24 PM
New Found Metal Libellula Gear & Maintenance 6 07-24-2012 08:14 PM
Restoring shine to metal parts (cleats, port hole metal) saurav16 Gear & Maintenance 23 11-19-2008 05:42 PM
Metal Plate gg30citation Gear & Maintenance 4 11-02-2007 11:31 PM
