Wood identification? - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree2Likes
Old 03-27-2015
UnionPacific's Avatar
Schooner Captain
UnionPacific is on a distinguished road
Can anyone tell what type of wood this is?
Galley Shelf Cabinet - TKRonaBoat
I would like to copy the design, and it matches my teak, however I do not know what type of wood this is. Is it teak, or something less expensive?
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 03-27-2015
Re: Wood identification?
Looks teaky to me....
UnionPacific likes this.
  #3
Old 03-27-2015
VallelyJ is on a distinguished road
Hard to tell without a close-up of the actual grain, but it sort of looks like ash. Should be hard, with rather open pores, like oak has. It was apparently not uncommon in boat interiors. It's a lot cheaper than teak. Unstained and un-oxidized, it's a light yellow, but could be stained to the present color.
JV
  #4
Old 03-27-2015
Schooner Captain
I know this is a hard one. Everything I googled online about wood identification was rather vague, and directed at unfinished wood.
I guess I should be asking then: What wood would work with such a project, and can be stained or varnished to match existing teak?
  #5
Old 03-27-2015
Ulladh is on a distinguished road
Looks like red oak. Get a small piece of red oak from a wood supply house and wet it then compare grain.
  #6
Old 03-27-2015
paul323 is on a distinguished road
Very difficult to tell from the photos. Looks a bit more yellow/red than teak. Possibly a mahogany variety? Could also be red oak, but the grain seems rather dense.
You may want to visit a local lumber yard; if you do, use an old cabinetmaker's trick: wipe some denatured alcohol on a wood sample to get quick idea of what it would look like when varnished.
I love teak, but am reluctant to recommend it to you because of the price. It is not only beautiful, but the oils/waxes in the pores make it very weather resistant. However, down below this is not so essential (hopefully), so there are a range of beautiful woods which can safely be used. Teak and cherry (can get dark), mahogany, ash, oak, maple; if you are building with plywood, walnut can look spectacular.
Find out what nice woods a reputable lumber yard has; take your time to inspect each piece. perhaps even mix and match (mahogany grabrails with ash storage units? Mahogany trim I like on lighter woods). Have fun!
  #7
Old 03-27-2015
seaner97 is on a distinguished road
Looks like oak, but ash also has a similar grain pattern. If it's interior to the boat, it is dry when you mill it and you seal/stain it appropriately, you can use darn near anything you would use on land. If you're someplace where the boat doesn't come out of the water, the relative humidity will actually be more stable and seasonal movement will be less. If you're going to go oak, white is more traditional for boat use.
Ocean- that which covers 3/4 of a world made for man, who has no gills.
  #8
Old 03-27-2015
SVTatia is on a distinguished road
Ipe.
A Brazilian hardwood that is becoming very popular...
I think its both - Ipe and Mahogany, but its hard to distinguish because of lighting, etc.
Beautiful woodwork nevertheless, there's definitely more to life than just teak..
  #9
Old 03-27-2015
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy will become famous soon enough
My guess would be mahogany. Red Oak usually has a tighter/finer grain. Of course, I could be wrong, too.
Gary
  #10
Old 03-27-2015
Oak and ash can look a lot alike. Colors on a monitor aren't reliable. No answer you're going to get on the internet is likely to be reliable enough to warrant going out and buying a load of hardwood. (Except perhaps mine, of course.) Seriously, you need to look at actual wood and stain samples, or have a wood person look at yours.
Go to a lumber yard that specializes in hardwoods and look at the different species. Look at the stain samples. Try a few scrap pieces from the 'cut-off' bin with different stains.
Bring a piece of the wood you want to match if you can. If you're doing a woodworking project, pulling an existing piece off shouldn't add that much to it.
Also, try searching on woodworkers' websites for teak look-a-likes.
JV
You may post attachments
You may edit your posts
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 28 05-15-2014 09:21 PM
Help with Identification Please? Kalina-Lona General Discussion (sailing related) 11 09-11-2012 05:18 AM
Battery identification Minnewaska Gear & Maintenance 49 04-10-2012 02:13 PM
Identification please imiloa Sailboat Design and Construction 5 09-15-2008 05:13 PM
Best wood-to-wood adhesive kwaltersmi Gear & Maintenance 16 10-27-2007 07:25 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
