Anti-fouling paint under the keel - SailNet Community
 10Likes
post #1 of 40 Old 03-30-2015 Thread Starter
Whitewater to Seawater
Zoya's Avatar
I know it's a bit of a tricky thing to do but I would assume dealer commissioning new boats do their best to paint the underside of the keel. Well, I hauled out today for a quick pressure wash to get her ready for spring and below is what I saw. Should I bitch about it or is that business as usual?
Zoya is offline
post #2 of 40 Old 03-30-2015
Once known as Hartley18
Classic30's Avatar
Dock
Re: Anti-fouling paint under the keel
Given that you can see patches of grey primer alongside the bare keel itself - I'd say that's just sloppy.
My boat goes back in tomorrow and for sure there'll be a guy standing right next to it armed with a tin of antifoul and a paintbrush ready to get to work the moment she's lifted in the slings.. or the yard will know all about it.
She looks like a beauty - good luck with her.
Classic30 is offline
post #3 of 40 Old 03-30-2015 Thread Starter
Zoya's Avatar
Thanks. I like to be reasonable but don't like to get cheated either...
Zoya is offline
post #4 of 40 Old 03-30-2015
Classic30's Avatar
Dock
If you point it out to them nicely, they'll likely just fix it on the spot at no cost to you..
It's really not a big deal - but, yes, it needs to be done and it's reasonable to ask them to do it.
post #5 of 40 Old 03-30-2015
Yards like to think one can antifoul the bottom of the keel just minutes before splashing. But it really does not work. The paint often blisters of simply falls off. If boatyards knew anything about boats...or cared about and quality service whatsoever...they would not do that.
The cheapskate workaround is to try to clean and sand the keel bottom just before shoring, then try to get an overnight or morning in the slings to dry the paint just before splashing. The proper way is to bargain for multiple lifts to move the shoring. And those lifts must be after the antifoul had cured a day or two. Expensive. That is of course what I do.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #6 of 40 Old 03-30-2015
Catalina 400 MKII
Scotty C-M's Avatar
Most yards (at least in my area) give you hang time of an hour or two to coat the bottom of the keel. I know for a fact that it works on Trinidad and Micron 66. boats that I have had with those bottoms look fine when I haul them a couple of years later.
I would be nice, but definitely ask about the lack of paint on the bottom. Not acceptable.
Scotty C-M is offline
post #7 of 40 Old 03-30-2015 Thread Starter
Zoya's Avatar
Dealer is 200 miles away so, not possibly to have them fix it but thanks all for your feedback, I feel vindicated....
Zoya is offline
post #8 of 40 Old 03-30-2015
TakeFive's Avatar
My river has 7' tidal swing, and depth in the lift area varies from 6' to -1' (a foot of mud). So my DIY boat club has a few hours to splash in daylight for a week, and the next week they don't do any splashes. So on the days that they can splash, they try to do ~4 boats in about 2 hours. There is no willingness to allow any boat to hang in the lifts for a few hours, or everyone would demand the same privilege. So our boats never get fully coated under the keel. I do try to paint the bottom of the wings, since they extend out over the edge of the wood bock. But the center of the wing, where the block supports it, never gets paint.
Getting them to lift the boat in the evening (for painting the keel) and spash early the next morning isn't really viable, because they're too drunk in the evening, and too hung over in the morning.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #9 of 40 Old 03-31-2015
Classic30's Avatar
Dock
FWIW, most ablative antifouls do not need to dry before splashing and there is certainly NO issues with putting them on as the boat heads for the water.. after all, general practice for decades was (and still is in many places) to antifoul between tides whilst lashed to careening piles, so the paint was and still is designed to handle that. Indeed some (I can't remember which ones) shouldn't be left too long before getting wet or they won't work properly at all! As in all things paint - read the tin.
The biggest issue after antifouling is always the bit under the straps... but if the yard uses cradles or blocks to sit the boat on, the lifting straps will naturally be positioned on fresh dry paint, so it's simply a matter of making sure someone is nearby with a tin of antifoul and a brush to do the bits under the keel after the boat is lifted and before it hits the water. So long as the straps don't damage the antifoul (and they usually don't), you're all good.
post #10 of 40 Old 03-31-2015
aeventyr60's Avatar
Good yards put a large piece of paper between the hull and straps to avoid any damage to fresh anti foul and your freshly waxed hull.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Paint Remover for anti-fouling paint cousineddy Gear & Maintenance 18 03-12-2016 04:50 PM
Ablative anti-fouling paint, One coat or ten? MedSailor Gear & Maintenance 29 03-14-2015 11:54 AM
Anti-Fouling Paint on an outboard? ericb760 Outboard 15 02-05-2014 06:59 PM
Anti-fouling paint on a trailerable boat? svTrekka General Discussion (sailing related) 8 10-26-2010 08:22 AM
anti-fouling paint recommendations mcagney Gear & Maintenance 8 02-12-2005 11:10 AM
