straighten furling foil - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree6Likes
Old 1 Week Ago
cmetzbower is on a distinguished road
Anybody know how to straighten a furling foil for the jib? It's not bent too bad, you can see it in the pic.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 1 Week Ago
RichH's Avatar
RichH will become famous soon enough
Re: straighten furling foil
If there is a local 'metal worker' who specialized in 'boilers', boiler repair or heat transfer equipment / heat exchanger building/repair ... this person will undoubtedly have a tube bending devices (rollers, jigs, etc.) and will 'most times' be able to correctly straighten a foil.
Unfortunately aluminum doest take kindly to much repeated bending ... so there is always a risk of fracture when re-straightening (or bending) aluminum.
  #3
Old 1 Week Ago
overbored's Avatar
overbored is on a distinguished road
are you sure it is bent or just laying there flexed to a curve. if it is bent it can be straightened but takes a little know how. some can be over flexed the opposite direction and will return to straight. I have done a few over the years but it is hard to tell someone how to do it. try it what do you have to lose.
Faster likes this.
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
  #4
Old 1 Week Ago
Hammer22 is on a distinguished road
To my untrained eye, that looks to me like a flexible furler, something akin to a CDI or hood seaflex. If so, an excerpt from the cdi manual has the answer: the furler can be "straightened by bending the luff in the opposite sense until it comes straight. Another option is to put the luff in a pipe or tube outside in the sun for one to two weeks to straighten it."
RobGallagher and RonRelyea like this.
  #5
Old 1 Week Ago
sony2000 is on a distinguished road
In my humble opinion, don't do anything. Tension on the backstay and you won't notice it.
BarryL likes this.
  #6
Old 6 Days Ago
BarryL's Avatar
BarryL is on a distinguished road
Agreed
Every time my rig has been down the furler has looked like that. Once back up and properly tensioned it looks and works just fine.
Barry
sailingfool likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
  #7
Old 6 Days Ago
Azzarac's Avatar
Azzarac is on a distinguished road
The make of the furler would be helpful. If that is a CDI flexfurl then it will most likely depend on the age of the furler as to whether it will straighten up or not since they become brittle over time. You could try placing it in a tube and allowing it to warm up in the sun as suggested on their site. I do not recommend trying to bend it in the opposite direction (personal experience here) as it will most likely crack. A replacement CDI luff is about $200.00 and readily available so not all is lost.
“If you surrender to the wind, you can ride it.” – Toni Morrison
"Sic gorgiamus allos subjectatos nunc"
Follow Chameleon's travels at:
  #8
Old 6 Days Ago
Its a Schaefer SnapFurl. I'm not sure of the exact model.
  #9
Old 5 Days Ago
Still a flexible furler. I'll second the comments about tensioning the rig. My own boat has a Hood SeaFlex, and the foil extrusion tends to bend a little when the rig is down for trailering. Just some of the "memory" curvature from how it was shipped that has never fully corrected itself. But if you notice curvature while its up and tensioned, laying it out in the sun in a tube should do the trick. Worked for me for a more severe bend that occurred due to how the PO stored the furler. Had found the info from CDI a few years ago, hence the reason I posted it for your sake earlier.
  #10
Old 5 Days Ago
If it's not visibly kinked, agree... install and tension rigging you will likely be fine.
You may post attachments
You may edit your posts
foil kits captmayhem Racing 6 09-27-2013 07:01 AM
Flex foil or aluminum foil for roller furling? fiatracer163 General Discussion (sailing related) 3 12-05-2011 10:23 AM
Lubricating Roller Furling Foil WanderingStar Gear & Maintenance 6 09-09-2011 11:44 PM
Missing Foil !!! doctorsign Gear & Maintenance 3 04-30-2009 09:51 AM
Hood Line rolling furling foil repair mjname Gear & Maintenance 5 11-11-2006 02:20 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
