More Ventilation in Aft Cabin --Center Cockpit with Dodger - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree3Likes
Old 04-15-2015
pdqaltair's Avatar
pdqaltair is on a distinguished road
Hatch scoops don't make sense; the dodger blocks the wind. Certainly you can open everything up, but the back end still cooks. Pulling/pushing air through from the forward cabins doesn't really work, since it is pre-heated during its passage through the boat. Better that warm air goes up the companionway.
I've seen wind scoops for the side hatches, but they seem awkward and small.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 04-15-2015
Re: More Ventilation in Aft Cabin --Center Cockpit with Dodger
A length of 'slinky' type dryer ducting/hose strung up along the lifelines facing the wind? Could add a larger 'funnel' style collector to it too... The hose itself would store quite compactly.
  #3
Old 04-15-2015
seaner97 is on a distinguished road
I feel like I'm pushing stuff today, but these posts are all related. Solar vents seem like the perfect solution here. I swear I have no interest in them. I've recently purchased and am installing two but in home testing, they move a lot of air. Combined with some method of passive air egress or ingress it should solve your problem.
  #4
Old 04-16-2015
pdqaltair's Avatar
Solar vents are even enough to count for anything in the summer. Honest. I have them in each cabin (twin aft cabins) and you can't tell if they are on or off. Just for humidity control, in my opinion.
tdw likes this.
  #5
Old 04-16-2015
capta's Avatar
Master Mariner
capta is on a distinguished road
We have the same problem and I am convinced that air egress is the answer. Many aft cabin boats have ports in the transom, which is ideal, but we have a large lazarette aft of the cabin, so we need another option. We can move plenty of air in, but with no way out, it can't create a flow, and the aft 4 feet of our cabin can get pretty warm.
There used to be a venturi funnel available that would move a tremendous amount of air without letting water in, but I can't find them anywhere and my post on the construction of one bombed out.
I don't know what's aft of your cabins, but if you can get the air to egress, you'll have no problem getting the air to pass through and cool the cabins. Properly designed, you might even be able to draw air in without the help of wind scoops or the like. We do get some relief using the O-2 Cool 10" 12 volt fans, but again with an egress, those would also work better.
Good luck.
facebook.com/svskippingstone
Our Videos;
  #6
Old 04-16-2015
pdqaltair's Avatar
Good luck.
I think you are on the right track. We have 2 small hatches that open onto the aft deck and a fair amount of air is sucked out. A small aft-facing funnel that would also block rain might be an answer. Gotta think on that.
MarkofSeaLife likes this.
  #7
Old 04-16-2015
And your vents are on exhaust? I found in my box tests that they did little unless there was ample air entry and they were in exhaust mode. Then they created a pretty decent wind tunnel. But I will bow to experience if you've already tried.
  #8
Old 04-16-2015
pdqaltair's Avatar
Yes, on vent.
I'm not sayin' they don't serve a function, just that in my siuation they are far too little when the thermometer hits 95F.
  #9
Old 04-16-2015
Well, if you have enough ways for air to get in, then I bow to your experience.
  #10
Old 04-16-2015
Barquito's Avatar
Barquito
Barquito is on a distinguished road
That would be my assumption, too. If your boat is hotter than the temp outside, then any ventilation will improve that, including solar fans. However, once things are in equilibrium, then what you really need is moving air to improve evaporation from the skin. Maybe if the solar fan was scaled up? Bigger panel, bigger battery, much more powerful fan. If any of you have whole-house fans, you know what I am thinking of.
Bristol 27
Cirque
You may post attachments
You may edit your posts
Center Cockpit Versus Aft Cockpit BlueWaterBlair General Discussion (sailing related) 58 03-19-2012 12:35 PM
S2 11, aft vs. center cockpit? batkins61 S2 1 07-16-2008 08:06 PM
Center Cockpit Engine Room Ventilation Concordia Gear & Maintenance 10 12-21-2006 04:35 PM
Center or Aft Cockpit Dan Dickison Buying a Boat Articles 0 09-09-2002 08:00 PM
Aft vs. Center Cockpit Hansdg53 Boat Review and Purchase Forum 7 06-25-2002 04:59 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
