08-18-2001
reverse polarity
It would be in your best interest to get with your harbormaster and have them get an electrician to that slip to fix the problem or move you back to your previous slip. What you have is a potentially dangerous situation. Your ground could be compromised and that means your entire AC volts system is compromised. Not sure I would want to use anything on the boat until the situation is corrected.
