Deck Scupper: Tiny Leak - SailNet Community
post #1 of 6 Old 04-24-2015 Thread Starter
Good Day.
One of my deck scuppers along the rail is designed as a through-deck with a very short hose on the underside taking a 90 turn to a through- hull where the water exits the side hull just under the rail. The through deck fitting is 47 years old and the source of just the slightest leak; the inside cabinet under the fitting, where the hose makes its turn, stores notepads and dish towels that get slightly damp after a rainstorm. I am talking drops, not cups of leakage.
Drilling out and reglassing a new fitting is plan b, but some sort of exterior penetrating sealant would be my first try. Can anyone recommend a product with penetrating properties that might be able to seep into the breach to stop this tiny leak?
Thanks!
hriehl1 is offline
post #2 of 6 Old 04-24-2015
Re: Deck Scupper: Tiny Leak
I got laughed at by some here last year when I fixed a similar problem with my cockpit drain but my fix worked.
The drain is a glassed in tube about 18" long, dating from 1981. I had very limited access to it from inside the boat but it was leaking. Shining a light down I could see many hairline cracks.
While still on the hard I sprayed an entire can of rubberized spray that is meant to repair eavestroughing leaks. Allowing about 5 hours between coats as per the instructions one can did at least 5 coats. I also reached inside as much as I could and blindly sprayed the tube where it passed through under the cockpit and the hull liner. It stopped most of the the leaking.
I have a 2nd can ($10) that I am adding more to the repair this year just because it is only $10. The end results stays flexible.
If you sprayed enough of it the misting may reach the leaking spots around the curves inside the hose and if you can see the hose inside the cabinet then spray some there. It is flexible but not tacky when it dries. The "asphalty" smell goes away in a day or two.
1981 Edel 665
Dock C, Lake Front Promenade
i_amcdn is offline
post #3 of 6 Old 04-24-2015
I break <-> I fix
SHNOOL's Avatar
Here's my take on these kinds of problems... They only get worse until you fix them correctly. I had leaky scuppers on my Capri 25... prior owner said "The boat always seems to get a tiny amount of water in the bilge, I rebedded everything, but can't find the leak, must be the lazarette gaskets!"
Yep 1 year later, still leaking like heck, I finally had had enough... Now I could see a water trail from inside the lazarette, to the bilge. no question it was from the scuppers. In the Capri 25, the scuppers are horizontal, directly through to the stern. There is about 3-4 inches of dead-space between the Glass of the transom and the glass of the cockpit... so there is a "tube" of sorts between. This I have since learned was run through what looks like a 2x4 (you know glassed in and resined up)...
Well, the "tube" was made of brass (which is good) but it was a 1982 boat, and eventually water ate through the brass, and started to rot the 2x4s. I know this because the tubes looked like this when I tried to take them out...
My solution was to break all the brass tube out, overdrill the hole to remove some of the soft wood, and epoxy the whole thing back to make it all watertight again. Water intrusion was stopped after that.
You might be able to make the leak slow some, you might be able to "patch" the cracking tube... but honestly, take a few minutes, make an access port, and replace the hose correctly and you'll be happy you did. Here's why I say this... Lets say the tube is on it's last legs... and you take a deluge rainfall, or worse a dump over the rail of wave... the extra weight/pressure overwhelms the tube now that ALL comes crashing in! Best case it's a mess worst case... well, I'll leave that to your imagination.
Leaks in scuppers are nothing to trifle with. Just saying. I am not trying to bring harbinger of doom or anything, I just think its a larger problem, if it is as you say.
"Rum Line" an S2 7.9 - cheap, fast, trailerable, and paid for.
SHNOOL is offline
post #4 of 6 Old 04-24-2015
Master Mariner
capta's Avatar
You might want to try Git Rot. It is a penetrating epoxy that is meant to run to reach hard to reach areas. Perhaps mix it up a bit thicker than normal?
facebook.com/svskippingstone
Our Videos;
capta is offline
post #5 of 6 Old 04-24-2015
This is the worst suggestion ever. I have no idea what I'm talking about, and this will probably not work.
As a band-aid, you might be able to put a string through the hose, tie a cotton ball or rag to one end, soak the ball/rag in plasti-dip, then pull it through the hose. If you do it enough, it might coat the inside of the hose.
jeremiahblatz is offline
post #6 of 6 Old 04-24-2015
I actually tried to do this but with some West Systems epoxy. I made a mess and it ended up being just a thin coat. I then thought of the eavestrough repair stuff as I was fixing my eaves.
1981 Edel 665
i_amcdn is offline
Deck fresh Water leak albrazzi Gear & Maintenance 13 01-19-2015 08:09 PM
Leak at mast wiring deck penetration Rusty123 Gear & Maintenance 17 01-03-2013 11:50 PM
Deck Drain / Fairlead Leak wsmurdoch Pacific Seacraft 4 04-11-2011 09:22 PM
Leak at hull/deck or toerail dennisvetter Gear & Maintenance 7 08-25-2007 11:32 AM
tiny leak in black iron fuel tank kathyspike Gear & Maintenance 2 11-17-2002 12:05 PM
