Yanmar 4JHE Problems - SailNet Community
post #1 of 13 Old 04-27-2015 Thread Starter
Last week I changed both my fuel filters, the Racor and the spin on Yanmar one. Cranked up after little bleeding and seemed fine. So come the weekend we were going to go off and cranked it and let it run awhile, turned it off and then did not want to fire. So figured still a little air in it and went and bled and cranked up easy enough. Went to get some fuel at the dock next door and it was idling fine. We back out into the river and then when started going forward noticed it would not throttle up. Seemed to be choking down. Figured still had some air. Could put in neutral and it would rev up. So did that a few times and put back in gear. Went a bit and figured it would clear itself out. It would only get up to around 1700-1800 RPM. At this stage thought maybe something was wrapped around the prop and binding it so went swimming to see. Nothing on prop, but it was fouled somewhat with barnacles. Cleaned that while there.
When tried to crank this time there was some racket in the back of the engine with what sounded like metal hitting metal type noises, so I shut it down. Looked down at the drive train and saw nothing apparent. Shifted the trans up and down a few time and didn't seem bound. Tried again and still doing it so shut it down and called Boat US to tow us in. First time in all these years ever used the tow policy which was good to have.
Someone at the marina who used to work on engines said he had seen bolts on the flywheel on a Yanmar back out on one and get into the gear box cover before. Can put in neutral and spin the shaft and don't hear or feel anything, so flywheel thought may make some sense. One thing also noticed yesterday when looking at it was, the air cleaner had some oil like dripping coming from it and when I removed it had a handful of oily sludge in it. Not sure if that was caused when it was so loaded it was blowing fuel back. Was not doing that before because that area stays clean and could see it had dripped on the pan. Oil on the dip stick looked normal. Not sure what to think or where to even start. Gearbox is a Kazaki KBW20.
Prior to this always starts fine, no shifting issues. Ran good
Any thoughts would be appreciated.
Thanks
Another Day
Endeavour 38
Mobile, AL
last mango is offline
post #2 of 13 Old 04-27-2015
RichH's Avatar
Re: Yanmar 4JHE Problems
You changed your filters; so, the highest probability is that you 'pinched' a filter gasket when reinstalling and its now 'sucking air'.
Second possibility is that the filter housing/bowl became 'misaligned' during the closure ... use your eyeballs to insure that the 'lips' of the 'wobbly' parts are in correct alignment (the knife-edge of the metal components are smack dab in the middle of the gasket or O-ring before and during and after the 'tightening'). The 'wobbliness' is from normal 'tolerances' of machining and forming; a precision assembly would cost upwards of 10X as much.
When changing fuel filters, consider to ALWAYS change the gaskets and O-rings for new (because such gaskets are subject to softening and swelling when in long term contact with especially the newer blends of diesel fuel); and, always lubricate the new gaskets to help prevent 'pinching' of the gaskets, etc. --- just wipe on some diesel oil to lubricate. ....... and then use your eyeballs when assembling to make sure the 'edges' are in dead center of those gaskets/O-rings.
RichH is offline
post #3 of 13 Old 04-27-2015
Catalina 400 MKII
Scotty C-M's Avatar
What Rich said makes sense. Also be sure that the filters are on tight enough.
Scotty C-M is offline
post #4 of 13 Old 04-27-2015
captflood's Avatar
GREETINGS EARTHLINGS; Have you cleaned the fuel lift pump fillters in the pump it has a fine mesh that gets gooed up hope this helps AS ALWAYS GO SAFE.
captflood is offline
post #5 of 13 Old 04-27-2015
hpeer's Avatar
If it's like mine there is no separate lift pump. If there is one its built into the injection pump.
No idea what to say about the metallic racket, that would bother me, a lot.
hpeer is offline
post #6 of 13 Old 04-27-2015
Don't know about the clanking but if your spin on Yanmar filter is like mine, it's got a little water sensor/drain assembly that screws in to the bottom of the filter. That drain assembly requires an o-ring that's easily lost and/or thrown away when it adheres unnoticed to the bottom of the old filter. Without it, you'll get a periodic drip of diesel out the drain fitting when the engine is sitting and you'll pull a teeny tiny bit of air at higher throttle settings.
Beyond that, I'd second the advice to take a close look at your Racors to make sure the gaskets are in good shape, including the T handle o-ring if you've got a turbine-style housing.
IStream is offline
post #7 of 13 Old 04-28-2015 Thread Starter
Have to check but do change the O rings with the filters and know the drain on the bottom of the Racor is good - changed it out prior with a cutoff off valve to make draining easy. Still wondering what would cause the diesel to blow back through air filter so heavy unless does that when the engine lugged down. Have it where I can get to the back to see where that sound is coming from. Now second guessing if it could be a valve stuck or one of the valve springs broke. Never been around one that had. I'm sure it won't be simple or cheap - it's a boat.
thanks
post #8 of 13 Old 04-28-2015
Closet Powerboater
MedSailor's Avatar
Did you replace the filters with 10 micron or 2? Sometimes 2 micron filters will not allow enough flow.
MedSailor
MedSailor is offline
post #9 of 13 Old 04-28-2015 Thread Starter
The Racor was a 10 micron. The Yanmar spin on was their standard one so assuming a 10 - which may be a dangerous thing to do.
post #10 of 13 Old 04-28-2015
Closet Powerboater
MedSailor's Avatar
No. 10micron primary and 10 micron secondary is what is normally done. If in doubt, check your manual.
MedSailor
Yanmar 40 HP 3JH3E engine problems johnlbailey Diesel 6 05-27-2014 08:57 PM
Yanmar 2GMF problems Kiltmadoc Diesel 6 08-22-2012 02:46 AM
yanmar 4JHE SVRovia Diesel 2 04-04-2011 11:09 PM
Prop Size for Crealock 37 w Yanmar 4JHE MarcHall Pacific Seacraft 0 07-19-2010 10:58 AM
Yanmar starting problems... marinesniper Gear & Maintenance 2 12-19-2006 11:45 PM
