Tips for installing new tank - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 2 Days Ago
asdf38's Avatar
asdf38 is on a distinguished road
I'm looking to permanently mount a 6 gallon water tank.
Any tips or pictures for mounting a rectangular tank in a non-rectangular boat?
I imagine I want to glass in a couple pieces of wood but I haven't decided how to do it. If it was semi-removable that would be a plus. It's only 6-gallons so it doesn't weigh a ton.
It's probably going under the port side setee which will have vertical fiberglass on one side and the curved hull on the other.
The boat originally had a 15-gallon tank which was, IIRC, curved to match the hull.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 2 Days Ago
aloof is on a distinguished road
Re: Tips for installing new tank
Glass in some beds to support it and maybe keep it from sliding around. Tie it down with something. That's the normal way. Protect any wood from rot.
Any clod can have the facts, but having opinions is an art. ó Charles McCabe
  #3
Old 2 Days Ago
JimsCAL's Avatar
JimsCAL is on a distinguished road
You want to make a platform for the tank to sit on. Exterior grade plywood should be fine for that. Then some blocks to keep the tank from moving around and a strap to hold it in place.
  #4
Old 2 Days Ago
What boat (EDIT: still Contessa 26?) and where are you going to put it? What's the access like?
You may post attachments
You may edit your posts
installing a new gas tank for my 28' boat CanadianNorth Diesel 13 01-22-2014 08:06 PM
installing holding tank in Seafarer 30 Relic Seafarer 1 06-04-2013 04:22 PM
Tips on Kerosene tank location, pressurizing & fuel lines WesterlyPageant Gear & Maintenance 3 10-14-2011 12:55 PM
Installing inspection port, SS water tank moonie5961 Gear & Maintenance 2 06-09-2009 02:12 AM
Aluminum fuel tank - installing an inspection plate rikhall Gear & Maintenance 7 02-24-2009 03:29 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
