encapsulated keel? - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree3Likes
Old 2 Weeks Ago
UnionPacific's Avatar
Schooner Captain
UnionPacific is on a distinguished road
encapsulated keel?
While cleaning the bottom of the keel today I noticed a few places on the bottom where the fiberglass is coming off the keel about 1'x1'. Behind all I can assume is the lead keel. Is this a big deal? Its coming off where we went aground several times. I know not every keel is encapsulated, so why are any of them?
I can fix it when I haul out this fall, but must I? I do not want the boat to be unsafe, or "get worse" because I ignored it. I also do not want to make a hard project out of something I could simply cut off and paint.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 2 Weeks Ago
deniseO30's Avatar
Oday30!
Re: encapsulated keel?
Back in in time ballast was internal. Full kneels were easy to fill with whatever..boats like ours are about the same. Lead great, lead and resin, cement, iron, whateverer, The problem is water, even worse, ice. Resin dosen't bond they didn't' use epoxy. Soon water gets between the glass and the whatever ballast there is. Then we start to see things like blisters bubbles peeling or worse!
My last project!
My boat is sold!
  #3
Old 2 Weeks Ago
sony2000 is on a distinguished road
Keep it dry.
I've been noticing one of my small bilges is dry, after the winter freeze up. I wasn't in October. Now if I put water in it, (hauled out), the water is gone three days later.
It has leaked into the encapsulated keel. Not good. My shiprite says I have to seal it, or the situation will get worse.
  #4
Old 2 Weeks Ago
Schooner Captain
Hmmm, well I guess the nice thing about the bottom of the keel is I can remove the separated parts, and do some fiberglass work. Even if it comes out looking like crap, no one will know :P
  #5
Old 2 Weeks Ago
RichH's Avatar
RichH will become famous soon enough
The danger with encapsulated keels is rusting of the iron. Ferric oxide (red rust) is less dense that iron and therefore can produce a LOT of pressure as it forms, potentially pushing and separating the 'fiberglass' apart and dropping the ballast out the now open bottom - a vastly much more rare event than failing keel bolts of a bolt on keel.
  #6
Old 2 Weeks Ago
Schooner Captain
Mine is lead.
  #7
Old 2 Weeks Ago
aloof is on a distinguished road
An encapsulated keel in one that has the ballast inside the hull. External keels (non-encapsulated) are bolted on. External keels will often have a thin layer of fiberglass as fairing. Sounds like this is what you have. The lead often gets exposed on groundings. Easy to fix on the next haulout.
Exposed lead on an encapsulated keel (no keel bolts) will be a bigger problem.
To get epoxy to stick to lead it can be "sanded in". West Systems has a write up on this...somewhere. Basically the first layer of epoxy is applied to the clean metal with gritty sandpaper.
UnionPacific likes this.
Any clod can have the facts, but having opinions is an art. — Charles McCabe
  #8
Old 2 Weeks Ago
RichH's Avatar
Originally Posted by UnionPacific View Post
Mine is lead.
Then you're damn lucky. Just 'strength fix' the hole.
  #9
Old 2 Weeks Ago
1' by 1' ... A square foot? Wow those are big. And a few of them? Or did you mean inches?
  #10
Old 2 Weeks Ago
Schooner Captain
Entirely contained in that one area. 1 foot squared. Wonder if anyone has ever tried to install a stainless steel "toe guard" on one. Something bolted, and epoxied onto the forward and bottom of the keel to protect it from dragging and getting wore off, as mine did.
You may post attachments
You may edit your posts
Encapsulated or Bolt On Keel? aasault Boat Review and Purchase Forum 46 2 Weeks Ago 04:00 PM
Rust in encapsulated keel?! aaronsailor Gear & Maintenance 22 07-19-2014 10:23 PM
Encapsulated Keel? L124C Sailboat Design and Construction 41 05-22-2013 08:40 PM
Crack in front of encapsulated keel FishFinder Gear & Maintenance 19 04-29-2013 12:09 PM
encapsulated keel 83XT4 Pacific Seacraft 13 01-09-2010 08:14 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
