Installing new sink faucet - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 1 Week Ago
bshock is on a distinguished road
Hi All, has anyone switched out their stock galley sink faucet with a faucet with a removable hose? My existing faucet, coupled with the smallish double sinks, make washing pots, pans, and normal sized plates a bit tricky. It'd be easier if the faucet had an integrated hose so I could really rinse it well without making as big a mess.
This is my existing setup:
This is the kind of thing I'd like:
do you see any reason why the switch would be a bad thing?
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 1 Week Ago
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Re: Installing new sink faucet
That looks like a Beneteau 393.
Before you go screwing around: there is a serious lack of space behind the sink to get the nuts on the faucets threads.
I changed mine about 5 tpyears ago and its a pain to put it mildly. No the sinks cannot come out as the bolts holding them in rust.
To replace my facucet its about a year over due - i am thinking of putting a 10 inch spacer, SS tube, longer threads and the nut on the end of the spacer tube.
Monumental pain.
Sea Life
Notes on a Circumnavigation:
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
bshock (1 Week Ago)
  #3
Old 1 Week Ago
deniseO30's Avatar
Oday30!
Not a problem at all.. the new faucet has 3/8" OD compression fittings and long plastic tubes.
The soap dispenser sometimes comes included with such faucets, you can drill a hole for that if you have room for the bottle under it.
the REAL PROBLEM is can you access the bottom? and you will need a "basin wrench"
Mark, that type uses a big threaded ring with set screws that pull down on the faucet flange
My last project!
My boat is sold!
The Following User Says Thank You to deniseO30 For This Useful Post:
bshock (1 Week Ago)
  #4
Old 1 Week Ago
Thanks Mark and Denise. Good tip about the type of wrench I'll need, Denise; and Mark, it's a Beneteau 361, but I'm sure it's not much different, if at all, from the B393 you referenced. I'm not happy to hear it's such a struggle to switch out. Before I go spending cash money though, I'll get up in there and see how difficult it will be.
  #5
Old 1 Week Ago
alctel is on a distinguished road
I replaced both sets of taps as part of the refit. To get the nuts off, I used an electric impact driver with a big socket (1 1/8" I think) on it
Liveaboard on a 1980 36' Hunter
  #6
Old 1 Week Ago
aloof is on a distinguished road
Yes, have fun with that project. My basin cannot be installed with the faucet in place because interference with the lever. The faucet cannot be installed with the basin in place because the is no access to the faucet fasteners.
But, yes, you can use the hose type faucets. That's what I have in the head.
Any clod can have the facts, but having opinions is an art. ó Charles McCabe
  #7
Old 1 Week Ago
Capt Len is on a distinguished road
By the time you've rumbled around under the sink for a while you may have cracked or bunged up the sink drains and the hose that goes directly into the ocean. Last thing you need is a back flow. The tap switch should be straight foreward .Note hot/cold lines while you can still see them.
  #8
Old 1 Week Ago
hpeer's Avatar
hpeer is on a distinguished road
Take a look at what whale sells. May work. Just the first link I found.
WHALE RT2498 - Whale Water Systems Mixer Combo Tap/Shower White RT2498 - Boaters Plus
You may post attachments
You may edit your posts
Installing electric faucet/plumbing MarkinKC Gear & Maintenance 22 04-21-2015 05:59 PM
Galley faucet question mondofromredondo Pacific Seacraft 7 12-31-2013 09:57 AM
vintage faucet? amyspins General Discussion (sailing related) 17 01-21-2012 06:45 PM
Galley faucet NonaCat22 Gear & Maintenance 0 06-23-2011 04:20 PM
Dual faucet showerhead menomurphy Gear & Maintenance 0 05-26-2003 06:06 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
