Bedding bare teak with butyl tape? (Maine's Bed-It) - SailNet Community
post #1 of 2 Old 06-03-2015 Thread Starter
Tanley's Avatar
Hopefully Maine will chime in...
It's worked great for our deck hardware, but I'm looking to rebed the toe rail next (teak to fiberglass) and I'm reading conflicting information.
Some guys on the wooden boat forums advise against using it for this application saying that the teak will absorb components of the butyl tape, causing it to dry out prematurely. I've also read here and on SBO that it can be done. I did a 24 hour test clamping Bed-It between two pieces of bare teak and it did leave behind a dark stain (for what it's worth).
Varnish/epoxy on the bottom of the toe rail and then butyl might be an option, but I'd like to avoid doing that as I prefer to leave the toe rail natural and not sure if sealing just the bottom would be effective. Is Sikaflex 291 a better option?
Tanley is offline
post #2 of 2 Old 06-04-2015
aeventyr60's Avatar
Re: Bedding bare teak with butyl tape? (Maine's Bed-It)
Getting ready to install 88 feet of teak cap rail...Will be going with sika flex. Some pics of steam bent rails...and a crude but effective steam chamber deep up a river in Thailand.
Temptation Steak n Shaft & Rudder 029.jpg   Temptation Steak n Shaft & Rudder 031.jpg   Temptation Steak n Shaft & Rudder 010.jpg
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
Bedding Deck Hardware With Butyl Tape Maine Sail Gear & Maintenance 423 01-18-2017 09:45 AM
Bedding Deadlights w/ Butyl tape, DC795 and Screws mmazour Gear & Maintenance 12 01-20-2016 06:01 AM
Where to get Butyl tape? Paladin27 Gear & Maintenance 31 02-23-2014 03:25 PM
Re-bedding Windows: 3M-4200 v. Butyl Tape saildork Gear & Maintenance 16 04-13-2011 02:08 PM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
