Fuel filter quandary - SailNet Community
 1Likes
  • 1 Post By RichH
post #1 of 3 Old 06-11-2015 Thread Starter
Master Mariner
capta's Avatar
I'm unable to get the correct secondary fuel filter for my Onan down this way, the Napa Gold 3124. However I was given a Napa Gold 3358 by the Napa guy in Grenada and he says it will do.
The 3358 comes with a small gasket that fits around the threaded stem which the 3124 does not have. I contacted Napa by chat today and they could not confirm that the two were interchangeable.
Anybody have any thoughts about this?
Part Number: FIL 3358
Product Line: NAPA Gold Filters
Attributes:
Fuel Filter Gasket O.D. (Inches) : 2.74"
Fuel Filter Gasket Thickness (Inches) : .275"
Fuel Filter Height (Inches) : 4.709"
Fuel Filter O.D. (Inches) : 3.015"
Fuel Filter Style : Spin-On Fuel
Gasket I.D. (Inches) : 2.37"
Fuel Filter Gasket O.D. (mm) : 70 mm
Fuel Filter Gasket Thickness (mm) : 7 mm
Fuel Filter Height (mm) : 120 mm
Fuel Filter Inlet Thread Size (mm) : 16x1.5 mm
Fuel Filter O.D. (mm) : 77 mm
Gasket I.D. (mm) : 60 mm
Part Number: FIL 3124
Attributes:
Fuel Filter Gasket O.D. (Inches) : 2.736"
Fuel Filter Gasket Thickness (Inches) : .226"
Fuel Filter Height (Inches) : 4.828"
Fuel Filter O.D. (Inches) : 2.939"
Fuel Filter Style : Spin-on Fuel Filter
Gasket I.D. (Inches) : 2.43"
Fuel Filter Gasket O.D. (mm) : 69 mm
Fuel Filter Gasket Thickness (mm) : 6 mm
Fuel Filter Height (mm) : 123 mm
Fuel Filter O.D. (mm) : 75 mm
Gasket I.D. (mm) : 62 mm
facebook.com/svskippingstone
Our Videos;
capta is offline
post #2 of 3 Old 06-11-2015
RichH's Avatar
Re: Fuel filter quandary
The 3358 is 10ÁM nominal rating; 3124 is 6ÁM nominal rating; both rated for 6-8 gpm max. flowrate ... since they both have nominal ratings, no significant difference, other than the 6ÁM might 'choke' a wee bit faster in a contaminated system.
capta likes this.
RichH is online now
The Following User Says Thank You to RichH For This Useful Post:
capta (06-11-2015)
post #3 of 3 Old 06-12-2015 Thread Starter
Master Mariner
capta's Avatar
OK.
I guess a clean 10mc filter beats a dirty 6mc filter, but seeing as my Racor is a 10mc I don't see a lot of value in the 3358.
Thanks for the added info. I'll try Wix and Fram crossovers and see what their mc rating is. I don't know where you got that info; I searched for a long time and above is all I found.
Our Videos;
capta is offline
Racor Fuel Filter dbruce85 Diesel 2 02-08-2012 06:44 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Fuel Filter ID? sailak Gear & Maintenance 3 09-30-2009 04:22 PM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 12:41 PM
