Yikes! I folded my mast - SailNet Community
 2Likes
  • 1 Post By Gladrags1
  • 1 Post By travlin-easy
post #1 of 6 Old 06-20-2015 Thread Starter
I hit a overhang branch on launch with my Nordica 16 and bent the mast beone repair. Dywer mast can slove the problem for 1 1/2 boat bucks. Any sugestins how to reduce that number before I pull the trigger?
Johnniegee is offline
post #2 of 6 Old 06-20-2015
Sailor
Gladrags1's Avatar
Re: Yikes! I folded my mast
That's probably your best bet but you can also cut the mast at the bend and insert a sleeve inside. That can get very tricky but will provide enough support, etc. you can also try to find used mast on line. Depends upon how long you want to wait until you go sailing again.
Tod
Sent from my iPhone using Tapatalk
travlineasy likes this.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 6 Old 06-20-2015
travlin-easy's Avatar
Check the local boat yards and marinas for derelict boats - you would be amazed at what you can find there and at bargain prices.
Gary
eherlihy likes this.
travlin-easy is offline
post #4 of 6 Old 06-21-2015 Thread Starter
Dwyer has a dr-2 mast that appears to be close to my original--it is a inch less in circumference. Diameter 2 1/4 original 2 5/16. My boat is heavy at just under a 1000 pounds but I think the slightly smaller mast is still enough. Thoughts?
post #5 of 6 Old 06-21-2015
Over Hill Sailing Club
smurphny's Avatar
You can surely wait for a used one or buy new but I'd definitely consider the sleeving method as mentioned above. It's very do-able to get a section of the exact mast extrusion, slit it along its length and remove enough to squeeze it just enough to slide inside, joining the sections at the break, then epoxy/rivet it in. Mast extrusion material is often available new by the foot.
smurphny is offline
post #6 of 6 Old 06-21-2015 Thread Starter
I have about 4 feet of sail slid compressed if I could find a exact mast extrusion I would just buy it but thanks for the input.
Stop the horns? Yikes! downeast450 General Discussion (sailing related) 26 07-11-2013 10:22 PM
Turned Around - Yikes! Merit25lovers General Discussion (sailing related) 14 10-16-2012 12:37 PM
Yikes! Shaft Broken Mr. Golasz Gear & Maintenance 13 07-25-2011 05:49 PM
Yikes Duck401k Gear & Maintenance 12 08-27-2008 09:38 AM
Yikes !! PBzeer Cruising & Liveaboard Forum 12 11-04-2007 08:34 AM
