Fiberglass hull repair - SailNet Community
post #1 of 6 Old 07-10-2015 Thread Starter
Unhappy Fiberglass hull repair
Can anyone recommend someone for a repair job to a fiberglfor a 1987 CAL33. The story goes that one side of the outside hull was melted/burned during a fire on the boat next to mine. The fire ate the epoxy and melted/charred the first few layers of roving but not through into the cabin. Any recommendations on individuals or yards near Portsmouth, NH would be greatly appreciated.
stormjib13 is offline
post #2 of 6 Old 07-10-2015
Less Senior Senior Member
Robin hood marina has a good reputation. Not cheap, however.
seaner97 is offline
post #3 of 6 Old 07-10-2015
You could try york harbor Marine or kittery point yacht yard, but I couldn't speak to the quality of their work. Certainly closer to you and may be worth getting quotes.
seaner97 is offline
post #4 of 6 Old 07-10-2015
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Fiberglass hull repair
Great Bay Marine is also a possibility.
My notes say there is 46' of clearance under the bridge to access Great Bay. More at low tide, of course.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #5 of 6 Old 07-10-2015
Moderator
Jeff_H's Avatar
You did not say how extensive the damaged area is in size, but as much as I hate to say this, it could easy cost way more to properly repair that kind of damage, than the boat is worth. The reality is that your hull is not epoxy (which in this case is a good thing since epoxy tolerates heat worse than polyester) but polyester, and enough heat to burn off the gelcoat and expose roving would be sufficient to destroy the strength of the laminate that is far beyond the damage that you can see. Cutting away that section of the boat with likely damage and building a fair and structural sound replacement is a very expensive proposition.
Make sure you get a firm fixed price from the yard before you spend any money moving the boat.
Jeff_H is offline
post #6 of 6 Old 07-12-2015
Or grind it out and do it yourself. Cheap, easy, can be more solid than it was.
divimon2000 is offline
Fiberglass Repair on Hull at Rudder Bolts on Prindle 16 Jonathan Morgan Gear & Maintenance 7 07-03-2015 09:15 PM
My First Fiberglass Repair meridiansahoy Gear & Maintenance 9 09-25-2012 10:07 PM
fiberglass repair hertfordnc General Discussion (sailing related) 21 08-21-2009 08:12 PM
Fiberglass repair the right way? davidpm Gear & Maintenance 31 12-08-2007 02:15 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
