beneteau 285 reefing - SailNet Community
post #1 of 6 Old 3 Weeks Ago Thread Starter
davidpm's Avatar
I helped put the sails on a beneteau 285.
I noticed that the two stainless loops on the bottom of the boom that are usually used to terminate the reefing lines were not fixed.
They are in a track that lets them slide back and forth.
Is that a Beneteau thing?
I've usually seen them fixed in place.
davidpm is offline
post #2 of 6 Old 3 Weeks Ago
HANUMAN
RobGallagher's Avatar
Re: beneteau 285 reefing
It's not just a Bene thing. You can adjust them to get the angle you need to get the sail in proper shape, not all sails have the cringle in the exact same spot, some boats have multiple main sails, if the track is long enough it can be used for multiple reef points with the same line, probably more reasons that I don't know about or can't remember at this time.
Cheers.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #3 of 6 Old 2 Weeks Ago
JimsCAL's Avatar
The ones on my Cal 33 are that way.
JimsCAL is offline
post #4 of 6 Old 2 Weeks Ago
ASA and PSIA Instructor
In many newer reefing setups the reefing lines are terminated around the boom with bowlines, no blocks or rings of any type. This allows the trimmed reefing line to to be pulled out as trimmed, stretching the foot.
sailingfool is offline
post #5 of 6 Old 2 Weeks Ago Thread Starter
davidpm's Avatar
Thank you all.
So i suspect that the idea is that the loop will just jamb and not slide forward.
That is what it seems to do.
davidpm is offline
post #6 of 6 Old 2 Weeks Ago
HANUMAN
Originally Posted by davidpm View Post
Thank you all.
Or, there may have been adjustable cheek blocks on the track at one time to lead the reefing line forward to a winch on the boom or a cleat?? Just a guess???
HANUMAN
'88 C&C 30 MKII
NOANK, CT
Beneteau First 285 msl Boat Review and Purchase Forum 13 03-28-2015 08:25 AM
Beneteau First 285 vs CS30 Advantex Boat Review and Purchase Forum 0 08-18-2014 11:56 PM
Deck Organizers Beneteau First 285 sarahufford News Feeds 2 09-14-2010 11:20 AM
Stiff rudder on Beneteau First 285 sealegsjim Gear & Maintenance 4 01-11-2008 09:37 AM
Beneteau first 285... what did I miss? jbarros Boat Review and Purchase Forum 2 12-23-2003 05:22 PM
