add this to tip of the day - SailNet Community
post #1 of 4 Old 08-02-2006 Thread Starter
After reading the tip of the day,I remembered the chevy vega aluminum block it had a cast iron head and steel bolts.this is a similar situtation as the steel bolts have to go in aluminum. the bolts would seize under the tourqe.there was a product called anti-seize compound that prevented the bolts from tearing up the dissimilar metal I wonder if useing this product on the threads of the SS screw/bolt along with the gasket would prevent the chemical reaction.
KenD is offline
post #2 of 4 Old 08-02-2006
Lanocote or anhydrous lanolin will perform the same function and prevent galvanic corrosion.
sailingdog is offline
post #3 of 4 Old 08-02-2006 Thread Starter
the anti seize compound works as a loc tite material also,Where is lanolin and lanocote available?
KenD is offline
post #4 of 4 Old 08-02-2006
Anhydrous lanolin is available at most pharmacies. Lanocote is available from most marine chandleries. BTW, Lanocote and Anhydrous Lanolin will also prevent galling in stainless steel fasteners used in stainless steel fittings.
Block Island trip cmendoza Cruising & Liveaboard Forum 22 07-24-2003 01:22 PM
Wish to pay for 1/2 day sailing excursions beachgoer Provisioning 2 11-08-2002 10:26 PM
Wish to pay for 1/2 day sailing excursions beachgoer Chartering 1 07-11-2002 03:45 PM
Wish to pay for 1/2 day sailing excursions beachgoer Cruising & Liveaboard Forum 0 06-05-2002 02:39 PM
Today''s Tip of the day Denr General Discussion (sailing related) 13 01-22-2002 12:01 PM
