tranny oil for perkins 4-107 - SailNet Community
post #1 of 5 Old 08-06-2006 Thread Starter
Hello: Does any one know the right tranny oil to put into a 1972 perkins 4-107?
Any help would be appriciated.
Marcus
marcus1800e is offline
post #2 of 5 Old 08-06-2006
johnr
What kind of transmission is it?
jr438234606 is offline
post #3 of 5 Old 08-06-2006 Thread Starter
the one that came with the engine and is described as for low lying motor set up, the engine manual dosnt cover it well. the stuff on the sstick looks like red atf
post #4 of 5 Old 08-07-2006
Morgan 382 Tropical Wave
The tranny behind our 4-108 in our Morgan is a Hurth - it takes ATF. There must be a name on teh transmission casing somewhere?
John_colpitts is offline
post #5 of 5 Old 08-08-2006
pigslo's Avatar
This site has pictures of both Hurth and Borg Warner transmissions. It is your 4107 has one or the other. There should be a plate that indentifies the make and model. They also ar vey knowledgeable and carry replacement parts going back many years.
www.marinegears.com/index.html
pigslo
pigslo is offline
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Yanmar oil leak rskaug Gear & Maintenance 0 01-04-2004 07:08 PM
Decreasing Oil Pressure primowon Gear & Maintenance 3 07-07-2003 06:52 AM
Oil Changer Pumps 808state Gear & Maintenance 4 10-11-2002 03:27 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
